Driving in snow, lock the differential?
When driving on snow, is it better to lock the differential?
If there is only a light dusting of snow, 1"-2", on the road, which is better?
What about the 3"-4" range?
Remember, your GX is full-time 4wd all the time. So, there is power going to both front and rear axle ALL THE TIME.
I would NOT lock the center diff. If you lock the center diff, VSC (stability control) turns OFF. I would just leave it in 4-HI and drive. VSC is your friend.
The only time that i would lock my center diff is when you anticipate that you will be buried in snow the next morning. If you lock the center diff before turning your car off for the night, then in the morning, you can power yourself out of the snow. Center diff would remain locked the next morning. Thus, VSC is OFF. In this scenario, VSC would be more a hindrance because it will cut engine power as soon as your wheel(s) start spinning...and this can become a problem when you try to power yourself out of a hole.
If you want to do dounuts, then lock the center diff and play.
Awesome. Good info to have. Thanks for the replies. And judging by the tire related threads I have read, the Michelins that came with my GX should do great as well. I'm in Sac, CA. When dirving up to the snow, will I need to carry chains, though I'll never need them? Not a cheap thing to have to buy just to drag arround.
with 1-2 inches leave the truck as is, with a foot or more lock the diff so you have 50/50 power split, you will notice the difference, in deep snow the traction control is kicking in thinking your slipping when your actually trying to power through deep snow banks/drifts, in certain situations you want to spin your tires, with the stability control/traction control on it's thinking your slipping.
your best bet is to hit a parking lot after a snow storm and try it with and without, you will see how the truck reachs, but for driving on plowed roads that just have moderate snow I would leave the truck in normal mode.
maybe more snow experienced drivers will share but I've noticed in normal driving you can't do donuts but once you lock the diff you can spin real easy
When the center diff. is locked and you do donuts in a parking lot does it have any negative affect on the GX? Would it be worse doing donuts with the center diff. not locked? I've been able to do donuts without locking the center diff., but it makes that constant chime sound and continues to brake each wheel.
These are my Tahoe wheels and tires:
Always drive safely and give yourself plenty of room in the snow
cmarshack, What brand/model winter tire did you go with?
Ya, plan on driving up to the Sierra/Tahoe area, hopefully next month. As far as my current tires, they have about a 1/4 of an inch of tread left of them.
I just drove in 20+ inches this past weekend, very rare in the DC area. Did not lock center diff. and my suspension is in the middle
(in general, I would tend toward sport overall though, since you want to 'feel' the road more in those conditions)
The truck drove great btw, I was seeking out the deeper ruts to put it to the test & no issues what so ever.
No need to lock the differential, the GX is all time 4 wheel drive it will handle any 3" to 4" inches with ease. I routinely drive through 7" of sand, been in 24" of snow and never locked up. Lock up if you feel like you are getting stuck and the traction control is preventing you from working the gas.
