How to reprogram Auto window + memory seat function
Old 12-01-07, 07:52 PM
mx22o
mx22o's Avatar
Default How to reprogram Auto window + memory seat function
My Auto window and memory seat function doesn't work and the light that's on the window roll down button blinks. How do I turn them back on? Is there a sequence in pushing buttons to turn them back on?
Old 12-01-07, 08:49 PM
ote111
ote111's Avatar
same thing happened to my IS. all i did was to roll down the window a little bit and roll it up and hold, don't release and wait for a "tick" sound. That should do it.
Old 12-01-07, 09:15 PM
mx22o
mx22o's Avatar
thanks, that worked. but my memory seats still don't work. any idea?
Old 12-02-07, 12:26 AM
ote111
ote111's Avatar
you can try this but i don't know if it will work. move the seat here and there and re-program the seat position again.
Old 12-03-07, 06:25 AM
The G Man
The G Man's Avatar
Did you try re-programming the memory seats. Every time you disconnect the battery, you have to re-program the windows, sunroof, memory seats and clock.
Old 12-10-07, 10:01 PM
mx22o
mx22o's Avatar
I've tried moving the mirrors again and repositioning the seats. When I hold #1 + Memory, it won't not beat as it's suppose to.
Old 12-11-07, 05:02 AM
BurgBoxstr
BurgBoxstr's Avatar
vehicle must be in park to program memory seats. Once in park, hold the "mem" button down then press the "1", "2, or "3" (if you have) button to lock it in. You'll get a beep confirmation.
For the windows, make sure you repeat the proceedure on each using the local switch (one on door itself). If goes in this order (and the blinking light on the local switch flashes to lead you along):
driver door
passenger front
passenger rear
driver rear
sunroof
Old 12-11-07, 07:53 AM
The G Man
The G Man's Avatar
Yes, make sure you hold down the memory button 1st, then the 1 or 2 button, not both at the same time.
Aus430
02-11-19 01:34 AM
Shervin350
09-20-12 01:42 PM
OneJay
SC- 1st Gen (1992-2000)
04-11-10 11:22 AM
nistno
05-09-09 10:37 AM
dandd2
07-23-05 06:23 PM
Quick Reply: How to reprogram Auto window + memory seat function
