Will FJ wheels fit a GX?
The install is really easy. I did it on my t4r limited wheels. The trick is to get them torqued correctly. Very low torque (IIRC it's in inch-lbs). My guess is the monkeys at the tire shops don't use a torque wrench on them, but I went to the trouble of doing it on mine. Good excuse to buy another torque wrench ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Find something to slide between the side of the monitor and the rim so it doesn't rotate and come in contact w/the rim when you tighten the nut. I used an old wood ruler.
Thanks
I hate to revive an old thread but I was curious if anyone had used the FJ plain black steel wheels on the GX470? It looks like most people could bolt on the TRD wheels just fine. I wasn’t sure if the steel wheels had the same bore size. I know the GX is a 108mm bore. Are the FJ stock steelies also 108mm?
ServiceGuy
GX - 2nd Gen (2010-2023)
10-27-14 03:45 PM
