Will FJ wheels fit a GX?
Old 12-05-07, 08:58 AM
jditom
jditom's Avatar
Default Will FJ wheels fit a GX?
FJ wheels on a GX?
Does anyone know if FJ wheels will fit on a GX470.
07 FJ, 08GX470.
Do TPMS fit on FJ wheels?
Thanks
Old 12-05-07, 10:04 AM
The G Man
The G Man's Avatar
I think someone here have already install FJ rims on the GX, I forgot who it was.
Old 12-05-07, 10:56 AM
jditom
jditom's Avatar
Looks like the bolt hole pattern is the same. The offset is similar. GX is 18mm, the FJ is 15mm.
Old 12-05-07, 11:37 AM
hsk73
hsk73's Avatar
But... isn't it just 17" though???
Old 12-05-07, 12:08 PM
GatorGreg
GatorGreg's Avatar
Yes, cmarshack has them. He has pics posted here:
https://www.clublexus.com/forums/sho...ight=cmarshack
Old 12-05-07, 12:12 PM
GatorGreg
GatorGreg's Avatar
Correctumundo ("yes" was too short )
Old 12-05-07, 03:33 PM
jditom
jditom's Avatar
So it looks like 17's will fit. I can get some cheep to put snow tires!
Old 12-06-07, 10:40 AM
stiles_s
stiles_s's Avatar
Yes, they'll fit, but I think you're off on the offset. IIRC GX is 25mm, FJ is 15mm.
Scott.
Old 12-06-07, 03:47 PM
jditom
jditom's Avatar
Anyone know for sure the offset of GX wheels?
Old 12-06-07, 05:28 PM
stiles_s
stiles_s's Avatar
I just double-checked:
GX OEM wheels: 17x7.5 et 25
and, fwiw
4runner Limited 18s: also et25 (I happen to be running them, and love 'em)
toyota tundra: et15
toyota fjcruiser: et15
Old 12-07-07, 07:48 AM
cmarshack
cmarshack's Avatar
You are right the offset is different. The Factory GX wheel is et25 and the FJ is et15. All this does is push the wheel 10mm towards the outside of the wheel well which gives it a slightly wider stance. In my opinion it looks better. In my post, which is referenced above, you can see pics on page two and read more about what I am running.
Old 12-07-07, 01:40 PM
jditom
jditom's Avatar
In that case I may leave the snows on the OEM and put 285's on the FJ wheels now that I will have more room since the rim is pushed outward!
Thanks
I am looking at Toyo Proxie ST 285/55/17 with the same diameter as OEM's.
Old 12-22-07, 01:56 AM
norcalGX
norcalGX's Avatar
cmarshack...did you hook up the Tire pressure monitors to the FJ wheels? if so was it a simple swap or did you have to band them to the wheel?
Old 12-22-07, 12:30 PM
jditom
jditom's Avatar
I just ordered some sensors from Carson at 25% off dealer price. Still about $88 each with the mounting kit. You see them on e-bay used from time to time but did not want to chance it. Install look real easy. Will post pic after I get them.
Old 12-22-07, 02:18 PM
stiles_s
stiles_s's Avatar
The install is really easy. I did it on my t4r limited wheels. The trick is to get them torqued correctly. Very low torque (IIRC it's in inch-lbs). My guess is the monkeys at the tire shops don't use a torque wrench on them, but I went to the trouble of doing it on mine. Good excuse to buy another torque wrench
Find something to slide between the side of the monitor and the rim so it doesn't rotate and come in contact w/the rim when you tighten the nut. I used an old wood ruler.
Quick Reply: Will FJ wheels fit a GX?
