Will the 4runner wheels fit the GX?
Old 01-04-08, 12:40 PM
bobinsofla
bobinsofla's Avatar
Default Will the 4runner wheels fit the GX?
I've seen on here that some of the members have 4Runner wheels on their GX. So the "newbie" question is will any and all of the toyota wheels intended for the 4runner fit the GX, i.e. bolt pattern and offsets are OK.
Also, how about any of the other Toyota trucks like the tundra and Sequioa, will they fit the GX?
Thanks,
Bob
Old 01-04-08, 02:27 PM
jditom
jditom's Avatar
17 and 18 4runner wheels are the same bolt patters and offset. FJ 17 will fit but has a 10mm difference in offset.
Old 01-04-08, 02:40 PM
bobinsofla
bobinsofla's Avatar
Default Thanks for the reply
Thanks for the info. I'm fighting the wheel upgrade itch but I think I'm losing>>>
Old 01-04-08, 02:52 PM
GatorGreg
GatorGreg's Avatar
I'm pretty sure the new Tundra/Sequoia has 5 lug wheels, so you can rule those out along with the TLC/LX which are also 5 lugs. The older Tundra/Sequoia I believe are 6 lugs, but not sure about the off-set.
Old 01-04-08, 11:20 PM
stiles_s
stiles_s's Avatar
Yes, the last-model tundra and sequoia wheels will fit. They have the same offset as the FJ wheels -- 15mm compared to our 25mm, which would push them "out" 10mm.
I thought hard about the sequoia wheels before deciding on the 18" t4r limited wheels. Love 'em.
Old 02-01-08, 03:07 PM
BLKGX470
BLKGX470's Avatar
hey stiles...got a pick of the wheels you got on? I've been wanting to upgrade mine as well.
Old 02-01-08, 06:03 PM
The G Man
The G Man's Avatar
Here you go, purplehazek had the 18" 4runner limited rims installed a while ago
https://www.clublexus.com/forums/sho...=4runner+wheel
Old 02-04-08, 10:57 AM
BLKGX470
BLKGX470's Avatar
yep...those are the ones i was eyeing on...thanks!
Old 02-04-08, 11:12 AM
stiles_s
stiles_s's Avatar
I love mine:
- they look like they belong on the truck -- look oem, yet a bit different
- they weigh the same as the OE wheels (at least my wheel+tire combos weigh the same (oe+bridgestone vs t4r+cross-terrains), which is rare when you go +1
- steering feel and responsiveness improves a bit, which is nice
- easy to clean
on the debit side:
- ride harshness does increase slightly -- as is typical in a +1 setup
- finish on the wheels doesn't seem to be quite up to Lexus standards (mine have a few chips in need of touchup already)
Old 02-04-08, 11:20 AM
BLKGX470
BLKGX470's Avatar
OH STILES...I'm really gonna have to get one...I wasn't really going to mod my GX...wife normally drives it...but I get to drive it on long drives and on weekends and I definitely want to get a set of the same ones...
Old 02-04-08, 01:13 PM
GatorGreg
GatorGreg's Avatar
I love mine
Me too, I recommend you go for it
Old 02-04-08, 02:49 PM
stiles_s
stiles_s's Avatar
Oh, and I forgot perhaps the best "benefit": they're cheap -- very cheap for OEM wheels. I think I paid $198/ea at the dealer. Strangely, this is significantly cheaper (almost 50%) the cost of the 17s on a 4runner sport.
Old 02-04-08, 03:32 PM
BLKGX470
BLKGX470's Avatar
oh, you got your set from the dealer? i thought you got it off ebay. so what did you tell the parts guy when he asked you what year and model?
which dealer did you get it from? toyota or lexus? and if you got it from toyota dealer, where did you get the lexus caps and for how much?
Old 02-04-08, 04:19 PM
stiles_s
stiles_s's Avatar
I bought a set of 4 wheels for a "2007 4runner Limited" at the local Toyota parts counter.
In addition, I bought Toyota center caps for mine. I know several people have come up with lexus-logo'd solutions for theirs -- I didn't bother; I kind of like the double-takes they generate.
Finally, I bought a set of 4 TPMS sensors online from lexus-parts dot com.
Old 02-05-08, 09:38 AM
BLKGX470
BLKGX470's Avatar
couldn't you use the OEM TPMS sensors in your old lexus tires before the swap? or is that necessary?
TPMS are tire pressure something something sensor, correct?
Quick Reply: Will the 4runner wheels fit the GX?
