Anyone have problem passing state inspection w/ XD HID Kit?
I don't know how some of the turbo and supercharged guys do it here
So for the visual inspections they will actually take off those 2 large black covers???
Az does inspections of cars over a certain age..if they are are computer run they just plug into the computer to read emmissions and codes.. if they they are older "analog" then they Dyno them
Well, any aftermarket intake (except K&N with the carb sticker) won't pass for the smog check. Most shops that see this will let you know that it'll fail and won't bother to test you.
No state inspections here in Minnesota, but the reason why the GX does not come with HID is because the DOT states that a Xenon projector cutoff shield can only be so high. This is in order to no blind on coming drivers with an elevated cutoff sheild, which is why Lexus choose to use halogen projectors for crisp lighting instead of producing a vehicle that wouldn't pass inspections.
And as far as how turbo'd and sc'd cars pass them, well you have to look at what forced induction is... it is actually increasing the volumetric efficiency, and if your not stomping on it like most drivers do, then you actually benefiting from the increased air flow to further lean your mixtures thus passing the test. When i lived in phoenix, i got 2 boosted cars through the inspections, plus if you have money into the vehicles you can also control the fuel trims even leaning it out even more.
In California a lamp/brake inspection is done if your vehicle is salvaged only and even then they are checking the level/aim of your headlights. Only went through this once many years ago. They did not look inside to see what kind of bulbs or lights I had.
For emissions as long as you have the CARB sticker on the intake you are good to go. It is entered into the computer. My SC430 with the Injen intake passed the last time around and it also has headers but they are not very visible so the visual went without a problem. My Tundra which also had headers also passed visual twice. Crossed my fingers on that one.
I think its more or less a Lexus / Toyota policy not to put HIDs on their higher trucks. I am not sure if they are trying to set a good example or what but sooner or later they will give in to consumer pressure. The technology is out there to safely put HID on truck with out blinding people. Even Acura finally gave in and start installing HIDs on their trucks.
My point is that it has to do with the height of the truck and the low beams, not rather the truck is unibody or body on frame.
LeslieRC, to tell you the truth, I do miss my GX. It was built solid unlike the GS. My GS only have a 1000 miles on it and the brakes are squeaking already and I got a slight rattle on my dash. According to the GS forums, those are very common problems on the new GS.
DOT states that the projector height has to be with in the ranges of 22" and 54" high. I am going to measure the GX, escalade, X5 and a few others, but i do believe the GX is slightly higher than the above mentioned... If you look at the new escalades, the projector is at the very bottom of the light and i would be willing to bet the height of the RDX or X5 is above 22 and below 54 inches.
Of course I know the XD kits are for show purposes only, but since I never drive at night, , I leave mine in all the time .
Anyhow, having PA state insp along w/ o&f change done at dealer later this week. So..... has anyone w/ a XD (or any HID) kit run into problems passing state insp while kit is functional? Not that it'll take too long to put the OEM halogens back in, I'd rather just leave as is (and hope to pass or that they don't notice )
Thoughts? Previous experiences?
Good Luck!
-Alex
In CA, you have to get smogged on a dyno every other year. In AZ, it's every year, but if the car is '96 or later, they just check your OBDII for bad codes and your gas cap seal. Pre '96 is dyno. Neither require safety inspections. One time, while waiting in line at the smog station, one car ahead of me had a radiator leaking like a sieve. The guy had to put fluid in the every few minutes to prevent it from draining dry. I've seen (mostly in CA) cars w/ no hoods, broken or non-existent head/tail lights, missing body panels, even no license plates (and the guy was using the sidewalk as a passing lane!! [This was in S. Central LA]). When I lived in central NYS, they required safety inspections (lights, brakes, etc), but since I kept my car registered in CA (was a student), I was exempt. They also (once a year) set up road blocks on every street leaving/entering town and checked every car's registration.
