How do you remove door courtesy lights
Door Lamps
OK, so I did this myself a few weeks ago and it took some prying. They do not come out as easily as I thought. The best bet...carefully (disclaimer) take a flat head screwdriver and slide it between the bottom of the plastic cover and the door skin. It will take a little more force then you are expecting for it to pop up. Now, I was not able to actual remove it completely, however I was able to hold the plastic cover up, slide my fingers in to remove the bulb and replace it.
Good luck!
Jason
Good luck!
Jason
Good luck!
Jason
Good luck!
Jason
Stereoca
04-09-10 05:43 AM
