40/45K mile service ???
Old 02-15-08, 02:58 PM
K-Bud
K-Bud's Avatar
Default 40/45K mile service ???
I was wondering if anyone knows or has a list of what the 40k mile service maintenance program that the Delearship suggest consists of?
I am gonna guess all it consists of is a bunch of checking sensors and loooking at stuff to see what might need to be addressed in the near future. i.e. tires, brakes, hoses, filters etc etc
Anyone know what it consists of exactly?
Thanks
Dan
Old 02-15-08, 05:31 PM
Bob GX
Bob GX's Avatar
Default 40,000 Mile Service or 48 Months
The Owner's Manual for my 04 GX lists the following:
- Replace engine oil & filter
- Replace air conditioner filter
- Rotate tires
- Visually inpspect brake pads/discs
- Road test the vehicle
If vehicle is operated primarily in desert, on dirt roads or while towing:
- Lubricate propeller shaft, retorque bolts
- Retorque drive shaft flange bolts
- inspect the following:
- ball joints & dust covers, drive shaft boots, engine air filter, nuts & bolts on chasis, steering linkage and boots
Old 02-15-08, 05:38 PM
Bob GX
Bob GX's Avatar
Default 45,000 Mile Service or 54 Months
- Rotate tires
- Visually inspect brake pads/discs
- Road test vehicle
- Inspect the following
- Ball joints & dust covers, body, brake lines & hoses, differential oil, drive shaft boots, engine coolant, exhaust pipe & mountings, rack & pinion assembly, steering linkage & boots
If vehicle is operated primarily in desert, on dirt roads, or while towing
- Replace differential oil
If vehicle is operated primarily on dirt roads
- Inspect nuts & bolts on body
- Inspect engine air filter
Old 02-16-08, 09:25 AM
<VENOM>
<VENOM>'s Avatar
I did not do a thing to my 4Runner and every time I had it at the dealer they told me everything looks fine, nothing until 60k, the only thing that was actually done was my friend greased the drive shafts at around 20 something and the dealer put new front pads on it at 40k plus it had a frozen passenger side front caliper that need to be replaced.
Be informed and do your research, some Toyota and Lexus dealers charge 500 for a 30k service and they do nothing except basic routine stuff anyone could do in there driveway.
If my friends Tacoma could go 120k before ha changed anything other then the oil and filter then these newer vehicles will do fine with the improved fluids they have in them.
snowy
RX - 3rd Gen (2010-2015)
17
01-03-16 07:15 AM
Flannagan
GX - 2nd Gen (2010-2023)
08-18-15 06:04 AM
mvallido
10-26-07 07:49 AM
koreanpers
Maintenance
10-28-03 06:17 PM
futuregs
Maintenance
07-10-03 09:03 AM
Quick Reply: 40/45K mile service ???
