Need to change the light bulb for 04 GX470, couldn't see any access from the cargo area. Anyone know how to access the light sockets? I did see two screws that holding the tail light asembler, is it the only way to change the light buld by removing the entire light cluster?
Open the rear door. There are two bolts-10mm i believe. Remove the two bolts and then pull the entire taillight out from the back. Replace the bulbs and then put it all back. Very easy.
