replacing blinkers in front headlight assembly
Old 04-04-08, 09:21 AM
smmart
smmart's Avatar
Default replacing blinkers in front headlight assembly
how do you remove front headlight assembly to replace blinkers? Gx470
Old 04-04-08, 10:30 AM
The G Man
The G Man's Avatar
You dont need to remove front headlight assembly, just remover the engines covers and you can get to it from the top.
Old 04-04-08, 11:16 AM
LexusBob
LexusBob's Avatar
You can also reach up from the bottom w/o removing anything. It's a little cumbersome but I've done it a couple of times already.
Old 04-04-08, 11:58 AM
brickauto
brickauto's Avatar
I personally feel it's easier to access from the bottom, just look straight up from the fog light housing and the bulb holder is a light gray plastic.
Old 06-07-08, 06:10 AM
Custom33
Custom33's Avatar
Default Running light replacement
Can anyone help with the best way to replace the running light? I have taken all the covers off and attempted to remove the headlight assembly, but I am obviously missing a clip or something...Can this also be changed from underneath?
Thanks!
This is my first post!
Old 06-09-08, 07:05 AM
The G Man
The G Man's Avatar
Yeah, it can be change from underneath and you dont need to remove the headlight assembly. Just reach your hand in there and locate the socket and turn.
fc3s
08-04-12 06:04 PM
tobyport
01-27-08 04:14 PM
RX469
RX - 1st Gen (1999-2003)
10-26-04 01:11 PM
Quick Reply: replacing blinkers in front headlight assembly
