Door Panel Removal Instructions
So I tinted my car today and in the past asked if there was any instructions on how to removal the door panel. The 1 write up that suggested wasn't quite the same as what the actual removal is so here's how to remove the door panel instructions. I didn't take every picture and on some of the pictures its a mix between the driver side and passenger side so if it looks inverted its because the picture I took was from the other side.
Step 1. Remove all items circled in red in no particular order.
Now that the snap plugs have been released you can remove the door panel from the window by grabbing it and pulling up away from the glass.
Note that there are many cable connections behind there so you can't go too far.
Disconnect all of the cable connections. There's a release tab that you press down then pull the entire connector out.
Next is the tricky part which deviates from the other instruction.
Because the door handle is connected to cabling you have to seperate the door handle from the door panel.
The only way to do this is by first removing the wood trim and then removing the door handle.
There are 6 screws behind the door panel that you have to unscrew.
Starting with the side that's farthest away from the door hinge. There are 3 screws - 2 that are visible and 1 that is hiding underneath the padding above where my finger is.
Note: I'm holding the padding down to show the hole where the screw is. The hole to the left of that is for a plastic stub that's part of the wood trim modeling.
Moving toward the middle but not quite behind the door handle underneath the padding are 2 hidden screws. You'll most likely have to cut the padding or scrape some of it away. This is right underneath the cabling that connects to the door handle.
