"Check Air Conditioner" message
I recently got this error message appear on my Nav screen and the A/C light in the climate control screen was flashing. The front A/C proceeded to blow hot air but the rear A/C was still blow cold air when I tested it at max cold.
Brought to the dealer for diagnostics and they found a bad Magclutch relay (part no. 90987-02028). The relay cost was $65.60.
Just a FYI to folks that might get this error, test the rear a/c to check if it's just a simple relay failure rather than the mechanical bits of the a/c system
Cooler Relay
Cooler Relay
9098702028, air, check, conditioner, conditioning, es300, gx470, lexes, lexus, message, nav, part, relay, rx350, screen
