GX470 loose door hinge?
Has anyone had any issues with their rear door of their GX470 not staying open? Everytime I am loading groceries I seem to get a slam in the back. Thoughts?
You need to lock it in place. After opening the door, there's a hinge on the bottom that you push in (i.e., towards the open door) to lock-in. To unlock, simply pull back in the opposite direction and then close door.
On my GX, I usually get away with just using the halfway indent where the door kind of catches a midway point and stays there by itself. Of course if its windy, or the vehicle is on an incline or I need the door wide open, I use the lever. Mine works very easily.
