Jump starting the GX
My friend has a fairly new GX < a year old, but they rarely ever drive it. This past weekend, he had to go pick up some friends at the airport, but the car wouldn't start. Tried hooking it up to a huge truck, similar to a ford f350 or so i believe. No go. Hooked it up to a red top optima to jump, and still no go.
I know its not a dead battery cell because tow truck came out before and it started after several attempts and half an hour, lol.
So how do you guys usually jump start the GX? Didn't know it could be so hard to jump start this car.
I know there is something strange with the GX’s electrical system. When I bought mine the guy who did the new car prep left the doors open all night and the battery was dead when I picked it up. They tried to jump it but it would not start. They actually had to leave it on a charger for about 15-20 minutes before jumping it then it worked. Very strange.
I think it has something to do with the stock battery. It will onlly take a charge at 2amp with my battery charger, anything higher and it will not charge.
Just call me "Sprinkes"
In my younger days, I would park the jumper car nose to nose, (when we had chrome bumpers) then use both cables as the Positive Cable.
~ Cap
The size of the other vehicle is unimportant. A Yugo with a working charging system will jump a GX or other 12v vehicle.
Also keep in mind that the negative clamp on the vehicle getting jumped should not be placed on the battery as a diode in the alternator or other electrical failure could occur. On a vehicle that depleted it is always best to disconnect the battery and charge it up. Not always the best possible solution if stranded.
Surprisingly it still had the new car smell but I was not happy about it! I am still on the original battery but will probably change it before this winter, the charge “eye” has never worked. The delivery coordinator was really mad and chewed the prep guys out.
cssnms
GX - 1st Gen (2003-2009)
26
01-31-14 02:36 PM
