Questions about our key
The plastic case on one of my keys has shattered. I see on ebay that you can buy blanks. My question is where is the RFID chip? Is it in the metal of the blade or is it in the remote entry part of the key?
The entire electronic portion can be switched from key to key by unscrewing and removing the cover (at least that's how it was on '03 models). I had the same problem that you describe so I bought a blank from an e-bay seller in the UK. Even delivered to Florida it cost a tiny fraction of what my dealer wanted (and the e-bay one is genuine Lexus/Toyota). I then took both keys to a local locksmith who can cut the channel type keys (you'll have to look for one who can, and won't rip you off for the procedure). Bottom line was that I had about $40 in my new key vs. a TON from the dealer (I don't recall exactly what the dealer wanted but it was outrageous).
The chip DOES reside in the plastic portion of the key, so if you broke the plastic part you are SOL. You can buy a new key on ebay, but the only problem is that starting with '06 (not sure, but maybe someone can correct), the only way to program a new key is via dealers diagnostics computer, so you have to pay them anyway. Open door, close door, open window, etc. procedure for programming the key is no more. It still may be cheaper than buying the new key from the dealer AND having them program it to the vehicle for you.
Are you saying that the '06+ (or some year) are not designed in such a way as to allow you to move the guts from key to key like you could with the earlier models?
If the remote part is intact, that may work. But, if the whole plastic part is in pieces ...... that becomes a problem.
BTW, the European plastic key is reportedly stronger, and from what I could tell by comparing mine, it seems so. The US case seems to flex more than the European one.
