GPS Navigation Update
#46
#47
piggypiggy, i have an 02 GX 470 that i want to update the nav... so based on your post, i should be getting Generation 2/3 version 10.1. thanks for your input. i will double check and call Sewell to ask if they have this version.
#51
#56
My version stinks. Im up here in canada and when it asks what area to look for and even though I punch in canada, a lot of times it searches for american.
My car is a 2004 US version (but again Im in canada) GS430. Where do I get my update?
And is there a step by step anywhere on here on how to do it? I dont want to screw up my navigation. Ive only had this car a few months now. I heard mention that the DVD is under the passenger seat so is all I do is pop that out and put in this new one?
And will this change the look? I would be thrilled if that was the case.
#57
you sure you have the region selected correctly? there are a lot of different regions and you need to make sure you select where you are, otherwise when you search, it will search for streets in another region
for the gs430 it's very similar, the nav ecu is in the trunk, i believe on the right (passenger) side
#58
Reading the same simple questions over and over in this thread is sad. Search first and then take the time to read your results... Seriously?
The overide trick to get boths screens to play a dvd and the breakdown on the software by make an model makes this thread useful. But 10 posts on asking how to insert a disc and wait? I stopped reading at the top of page 4 so please forgive me if someone elses useful tips are still burried under hand outs.
#59
I searched up and down this entire thread and see nothing about how to upgrade the map for a 2008 LS460. Any advice would be greatly appreciated. Thanks...
I will post it again FYI.
lexus / TOYOTA latest NAV GPS upgrade dvd version 10.1 for 2011 map, released in Sep.,2010.
I WILL HELP YOU TO INSTALL if you are nearby.
Please find your car's model and year made then let me know.
Some cars may be using Generation 1, that may not working with the DVD below.
vendor made GPS DVDs, Gen 2/3 version 10.1 , Gen 4: version 10.1, Gen 5, version 10.1 .
Vehicle Model Model Year
Generation 2/3 version 10.1 (override function still working on gen2/3 10.1)
FOR:
Lexus Es300 2002-2003
Lexus GS430 2001-2005 (not recommended for 2001 thru 2002)
Lexus GS300 2001-2005 (not recommended for 2001 thru 2002)
Lexus GX470 2003-2004
Lexus IS300 2002-2005
Lexus LS430 2001-2003 (not recommended for 2001-2002)
Lexus SC430 2002-2004 (not recommended for 2002)
Lexus RX300/330 2001-2004 (not recommended for 2001 thru 2002)
Lexus
2001-2003 LX470
Toyota Camry 2002-2003
toyota Sienna 2002-2004
Toyota 4Runner 2002-2004
Toyota Land Cruiser 2001-2003 (not recommended for 2001 thru 2002)
Toyota Prius 2001-2003
Toyota Avalon 2002-2007
Generation 4 V10.1
Lexus ES330 2004-2006
Lexus GS300 2006
Lexus GS430 2006
Lexus GX470 2005-2006
Lexus LS430 2004-2006
Lexus LX470 2004-2007
Lexus RX330 2005-2006
Lexus RS400h 2006
Lexus SC430 2005-2009
Toyota Camry 2004-2006
Toyota Solara 2004-2006
Toyota Highlander 2004-2006
Toyota Sienna 2005
Toyota 4Runner 2005-2006
Toyota Prius 2004-2005
Toyota Sequoia 2005-2007
Generation 5 V10.1
This DVD fits Toyota and Lexus Generation 5 Navigation Systems The following vehicles use the Generation 5 Navigation system:
Generation 5 Lexus / Toyota Vehicles:
Lexus ES350 2007-2009
Lexus GS350 / GS430 / GS450h / GS460 2007-2009
Lexus GS450h 2007-2009
Lexus GX470 2007-2009
Lexus GS430 2007-2009
Lexus GS460 2007-2009
Lexus IS250/350/F 2006-2009
Lexus RX340 / RX350 2007-2009
Lexus RX400h 2007-2009
Toyota:
2006 - 2009: 4RUNNER
2007 -2009: CAMRY
2008 - 2009: HIGHLANDER
2008 - 2009: LANDCRUISER
2006- 2009: PRIUS (dosesnt work on Gen5 prius based on my exp.)
2008 - 2009: SEQUOIA
2006 - 2009: SIENNA
2007 - 2009: SOLARA
2007 - 2009: TUNDRA
* All other toyota years and model not listed belong to generation 5
Generation 5 V10.1
* The "I agree" button is removed
* CANADA, Hawaii map is also included in the disc
TOYOTA LEXUS PRIUS NAVIGATION DVD UPGRADE GPS UPDATE
GEN5 10.1 GEN4 10.1 GEN3 V10.1
GENERATION5 10.1 VER10.1 V10.1
GENERATION4 10.1 VER10.1 V10.1
GENERATION3 10.1 VER10.1 V10.1
FOR 2011
FOR:
Lexus
2001-2003 LX470
Generation 4 V10.1
Lexus GS300 2006
Lexus GS430 2006
Lexus RS400h 2006
Toyota Sienna 2005
Generation 5 V10.1
Toyota:
2007 -2009: CAMRY
2006 - 2009: SIENNA
2007 - 2009: SOLARA
2007 - 2009: TUNDRA
Generation 5 V10.1
FOR 2011
