After market double din GPS/DVD/MP3 player install
Old 03-26-12, 10:32 AM
  #31
clubsport
clubsport's Avatar
going back and looking at my install i would have to say thank you to:
charlie@jd
desolate
for a very fine thread re double din install: all the info right here to make one very intimidating task seem like childplay
thanx again... enjoy all!
Old 03-30-12, 01:13 PM
  #32
clubsport
clubsport's Avatar
going back to look at the op double din install... Eclipse AVN5500
that is a motorized slide down system just like mine but yet op never mentioned an issue of the face coming into contact with bezel din - mine is a detachable face plate and i thicker so that could be why i had to do a mod to the bezel din to get rid of the contact issue
Old 04-01-12, 12:52 PM
  #33
clubsport
clubsport's Avatar
Default diagrahm
well i added to the diagram label to clarify how the four (five) wires will be connected:
the brake shift control (ie safety 5th) wire should be grounded either to a bolt on radio or the ground wire to bypass the emergency brake which won't wont work anyway so you must ground the brake wire regardless whether you want the safety feature or not... gl
Attached Thumbnails After market double din GPS/DVD/MP3 player install-tyto-01.jpg
Old 04-08-12, 09:35 PM
  #34
2OnyxLexus
2OnyxLexus's Avatar
Do you still keep the steering wheel audio control functions?
Old 04-09-12, 08:35 AM
  #35
desolate
desolate's Avatar
Yes, see my post here https://www.clublexus.com/forums/gx-...ml#post6977584
Old 04-13-12, 10:35 AM
  #36
charlie@jd
charlie@jd's Avatar
sorry i just revisited this post. there's no contact to any part of the bezel at all. it's awesome! i'm at 198k and no issues!
glad i did this write up. at least someone is using it for reference and improving the write up..
i apologize for the lazy style documentation. i didn't think anyone would be interested in it. i just documented it so i can go back and see what i did.
but thanks to all that improved this write up, good job everyone! thanks
Old 04-13-12, 12:11 PM
  #37
clubsport
clubsport's Avatar
hey y'all: nice to see y'all r still alive...
Old 01-05-13, 03:30 PM
  #38
monasterio
monasterio's Avatar
Default Please help
I have a 2004 GX470 with the stock nav and need a picture of the climate control wiring harness on a non-nav gx. I recently purchased a used climate control unit but the plugs in the back are not the same. Can someone please help me out?
ZeekGS300
GS - 1st Gen (1993-1997)
11-23-06 10:33 AM
saelee39
10-13-06 11:39 AM
chobits
08-22-06 04:54 PM
Quick Reply: After market double din GPS/DVD/MP3 player install
