low beam replacement
I need to replace my low beams (driver side blown), nothing fancy just want to replace them with normal bulbs. is there anyone who has a step by step procedure?
Thanks
Thanks
There is no need to remove the engine cover. For the driver's side, the only thing that might help would be removing the battery in order to give you a little more room to work with.
Hope I made a good decision, since one bulb has already blown out i am going to replace both high and low beams all around. I purchased PIAA xtrme white plus and the super plasma GTX for high beams.
I always replace bulbs by the pair, but there is really no need to replace the high beam. I thought you said you just wanted normal bulbs and nothing fancy
Piaas are nice quality but over price.
