Need Help- Can you identify these wheels?
With all of you well-educated experts out there, someone must be able to identify these wheels:
http://www.asantilexanigrilles.com/s...rts/107200.jpg
Also...
1) What is the maximum wheel size I can put on a Lexus GX470? 22, 24, 26?
2) What size tires would you recommend / should I be using for 22, 24 or 26?
3) Is the stability f/ roll-over actor significantly impacted with 22, 24, 26? I would assume so, but, please give me your feedback.
Thank you in advance for your help!
Cheers.
Also...
Cheers.
Thank you very much for the response. I agree that I probably should not go higher than 22". However, please help me understand why this is your recommendation. I'm learning, so... hook a brother up! = )
I have 22's as well and personally think that they are perfect for the GX. Anything bigger will probably not go over well on this forum (it took a couple of years for people to catch on to the 22's around here). That being said, it is up to you and your personal preference.
On a side note I wonder if this is a pshop or if they somehow greyed out the reflectors up front...I like it!!!
Back to your question...these look like 24's
BTW, mine rub very slightly on the inner fender liner when fully locked out in a turn a while hitting a bump (like making a hard turn into a driveway). But nothing bad at all.
i had the same question, cause i wanna get 22's but im not sure about the right tire size so that i don't rub! and this might sound stupid but what exactly is the offset and what should it be with 22's to prevent rubing??
24's no problem no rub, selling to do 26's
I have 24" boss 330's on my gx with a 15 offset with a 295/35/24 falken tire, I have no clearance problems at all. I am putting 26" asanti wheels on with the same offset with a 295/30/26.
What is the driving experience like with 22s
I understand the visual aspects of going to 22s. What is it like driving with this size tire? Can somebody describe it there is a different feel and what that feel is relative to the stock size of 17 inch. do you buy them for looks and getter better performance on the street. Of do you buy for looks but give up some things? If so what are the pros and cons? Obviously I am referring to street performance. Thanks,
