Key Fob or Door Lock Broken GX470
Past few days key fob on '03 only works sporadically to open/close doors. Now Fob does not work most of time and actual key on fob is not working/opening front driver door. Afraid to lock car at all now. Is this a Fob problem?
In past year have had 3 incidences of actual door locks not working or breaking. Lock(s) would not open w/fob, driver door switch, or manually. Replaced one rear door lock for $600+ (and they had to replace days later again as "new" cable was "stretched" and didnt work. they came to house & fixed in driveway in about 20 minutes!).
Could this be a door lock issue or possibly just a key fob problem (battery or otherwise).
If it is an 03 then replace the battery in the key fob - easy and cheap way to tell. It probably is about time to change it anyway. I just changed mine the other month, the range where the key worked was getting smaller and smaller.
having sorta the same issue yesterday , I went to lock /unlock the 04 GX470 and it won't open kinda does and doesn't any help ?
what type of battery does the key holder need and where can I purchase ?
I have extended warranty , will my warranty cover the key or locks ?
TIA
TIA
TIA
TIA
it is Panasonic CR2025, you can get these in any watch repair shop also. The screw on the key are very small, similar to the size on the glass frames. Ideally just ask the watch shop to have it replaced. And keep a spare one in the vehicle whenever needed. I replaced last month it costed me 1.5$ only. Next check your battery on the vehicle what volt is presently with a volt meter, sometimes the door will not activate if the vehicle battery is depleted.
thanks everyone , I did try the other key I have and it works fine , so can I assume it;s just the battery ?
going to get a battery ....
mann777, thanks for the heads up on going to a watch repair shop .. might be the better way and they can open and change ..
Blueben
RX - 1st Gen (1999-2003)
06-13-17 02:57 PM
