Pink/Red fluid on the garage floor
Old 03-13-14, 02:20 PM
Lmcqueen
Lmcqueen's Avatar
Originally Posted by 470reasons
I've got a 32oz bottle of Lucas engine oil stop leak sitting here waiting to go in the CRX. Hope it stops the minor camshaft oil seal leak. After owning a British sports car, it's hard to put ANY faith in a product branded "LUCAS". Glad to hear the Lucas stuff worked on your power steering leak.
Mmmmm, CRX.... Of all cars I've owned, one I miss the most is my college car, 86 CRX si.
Someone from yotatech recommended Lucas and it worked for me.
Old 03-13-14, 04:25 PM
Danger81
Danger81's Avatar
Default Thanks Burny!
Originally Posted by burny
We have a couple different people asking. The guy with the ES posted in the wrong forum, but I really believe his 07 ES is a water pump. He can check the weep ho to see if there is any pink crust around that bad boy.
Thanks for the reply Burny, I'm new to this and I see now that you're correct, I am in the wrong forum. (Embarrassing) I hate computers!!! So you think it's the water pump? Isn't that usually in the front of the motor? There's so much blocking my view that I can't really see anything. But I think that you could be right and if so I guess I should just take it to the dealer. I just moved to this area and don't really know anyone else to take it to. Bend over, here it comes.
Old 03-13-14, 04:38 PM
burny
burny's Avatar
If you have a 10MM socket or a phillips head screw driver and some ramps, you can remove the underneath cover where the oil filter is and look up in there with a flashlight to see the water pump weep hole. Look for pink crystals and also look at radiator while under there for pink crystals. Go to ES forum and ask for recommendations on independent mechanic in CT
Old 03-13-14, 04:59 PM
Danger81
Danger81's Avatar
Burny,
I just checked the radiator fluid level, a little low, but it's definitely a pink color. I'm thinking that you're right. I really appreciate the advice, THANK YOU!!!
Mcaple
02-11-17 08:28 AM
wandad47
GX - 1st Gen (2003-2009)
06-18-14 06:44 AM
cwolaw
06-02-14 08:53 PM
sojah
11-22-10 03:22 PM
kelleher2
04-02-10 02:17 PM
Quick Reply: Pink/Red fluid on the garage floor
