Replacing a cracked tail light cover
I need to replace my driver's side tail light assembly. Based on my ebay searching, it looks like I can pick one up for about $100 (with no bulbs or wiring harness). I am guessing it should be an easy DIY project...but I just wanted to check to see if anyone has ran into any problems when trying to replace a tail light assembly.
Thanks.
Thanks.
You're correct. This is an easy DIY.
Once you swing open the rear door, you will see a couple of bolts that just need to be unscrewed and then the tail light assembly can be pulled loose.
calvin2376
09-28-11 12:40 PM
