90000 service
90000 service
90000 miles service
what is the cost?
they are charging $3.350.00 for the service, and they offer free coffee, cookies, doughnut,
what is the cost?
That's some expensive donuts! I'll venture to guess it includes replacing the timing belt and water pump. Save yourself some $ and take your GX to Toyota, but be forewarned you have to pay for your coffee there.
Here is the Service chart for 90K
Replace engine oil and oil filter; reset reminder light
❏ Rotate tires
❏ Clean air conditioner filter (RX)
❏ Lubricate drive shaft, re-torque nuts and bolts (GX, LX)
❏ Visually inspect brake pads and rotors
❏ Road-test vehicle
❏ Inspect the following:
___Active height control system (LX)
___Axle shaft boots
___Ball joints and dust covers
___Body
___Brake lines and hoses
___Drive belt
___Engine coolant (see page 68)
Additional Maintenance Required If You Drive Primarily Under the Following Conditions
Driving off-road, on dirt roads or on dusty roads:
❏ Inspect engine air filter
❏ Tighten nuts and bolts on chassis
Driving while towing:
❏ Replace front differential oil (GX, LX)
❏ Replace rear differential oil (AWD/4WD only)
❏ Replace transfer case oil (RX AWD only)
___Exhaust pipes and mountings
___Front differential oil (GX, LX)
___Rack and pinion assembly
___Rear differential oil (AWD/4WD only)
___Steering linkage and boots
___Transfer case oil (RX AWD only).
But regardless of the condition
The following is changed for me. 8Plugs/Timing Belt / Water Pump, All Engine/Trans oils & Filters replaced. My Front Wheel Axle Boot was replaced. Had the Wheels Balanced ( was bit off) All for 2750/- 1 year back, with a cheap smile , and the freebies ( coffee/ Warped 18th Century Donuts).
❏ Rotate tires
❏ Road-test vehicle
___Axle shaft boots
___Body
___Drive belt
Based on Lexus Corp and SM....lengthy chat...
Get the TB changed because they will have to remove the water pump to get at it ..rather spend $2,300 than $68K PLUS for a new GX....PLUS...if maintained, the vehicle as outlined the GX will last you over 200K miles.....
17801-50040 ELEMENT AIR LIST 27.00 COST 20.69
23300-50120 FILTER FUEL LIST 55.59 COST 42.44
90915-YZZD3 FILTER, OIL LIST 5.41 COST 4.11
12204-50030 VALVE PCV LIST 8.64 COST 6.59
87139-47010-83 ELEMENT, CABIN LIST 20.99 COST 16.12
90916-02586 BELT, DRIVE LIST 51.88 COST 39.61
90080-91180 PLUG, SPARK IRRIDIUM LIST 10.37 COST 7.90
13505-0F010 IDLER TB LIST 88.45 COST 67.54
13540-50030 TENSIONER TB LIST 56.16 COST 42.88
13503-0F010 IDLER TB LIST 88.83 COST 67.82
13568-09070 BELT, TB LIST 52.33 COST 39.95
16100-59275-83 PUMP ASSY WATER LIST 143.07 COST 109.02
16346-50010 GASKET, T/STAT LIST 4.32 COST 3.29
90916-03100 THERMOSTAT LIST 18.99 COST 14.50
96761-35035 RING, O LIST 3.54 COST 2.71
__________________
Thanks,
Curt Aigner -- Elmhurst Toyota
630.279.2265 parts direct
630.835.0122 parts fax
it's 90k, timing bell, and now they found the radiator leak, front brake. my total bill would be around $4000.00 plus tax. that is with a 20% off coupon.
they have starbuck and tully coffee, and fresh baked cookies...and the staff are wonderful..any one want to know where this dealer is? i will be happy to share.
LOL $4K sounds insanely expensive to me, even with a new radiator, new brake rotors and pads, and pretty much anything else one might/should realistically replace. Do you have a list of what they're doing?
Next they will be telling you that you need a new paint job!!!!
Show this list what they are going to do for you...
You dont need a paint job....BUT THEY SURE ARE GIVING YOU A SNOW JOB!
The location of these bandits? I make sure that place is input on my nav system as to AVOID...DETOUR...
I'm about to do mine -- ordered the parts from Elmhurst Toyota, everything below plus all the fluids except engine oil for ~$650. Your dealer must be also doing wheel bearings, new rotors and pads, and perhaps other things, otherwise it sounds pretty steep.
__________________
Thanks,
__________________
Thanks,
