no power after turn off engine
Help""""" i need help, all the power stuff is not working after i turn off the car(light, remote key, clock......... , it will work when i turn on the car.the clock will reset at 1:00 tried to adjust but it didn't respond, i wonder if it's the fuse any one know Please help. Thanks ater spend $4300 for the 90000 service last month, i don't want to go back to the dealer, who know what they will charge for this.
If you don't get any results here you might have some luck on the 4-Runner forums. Of course it's the same basic platform, and some of those guys are much more DIY'ers than the GX gang, generally speaking. That's the beauty of owning a vehicle/platform that is frequently modded, customized and maintained by the owners -- a lot of underlying detail becomes known. That's the way it is for the Supra -- there is literally NOTHING that isn't clearly known and understood about those cars, so you can find any info you might need relatively easily.
Replacing a fuse is typically a short-term solution. If the problem resurfaces, take your vehicle to a reputable Toyota service department and keep money in your pocket!
IanB2 (09-21-21)
