AC System Cap with the "L" for freon
Hello,
Could you please advise (maybe pic) where I can locate cap with the "L" to recharge freon from the AC recharge kit. I can locate cap with only "H" high pressure on it but I believe the Kit needs to be connected to "Low pressure" cap based on cap diameter.
Please advise. Thank you!
Hi Philly
Here is the attached image sequence you can go about.
First Remove the Plastic Dust Covers covering the Engine Air Filter. The Marked circle are the Plastic Push Release. Just need to be careful on the removal part.
Now the second part of the image is which I have point and circled has a Green Cap, mentioned "L". Thats the Low PX Fillet Point for the R134A. This is what you are looking for, Hope it helps.
So long !!
So long !!
