HID fog install . . .
#31
I ordered my HID Kit from DDM Tuning. They are $40 and come with a lifetime warranty. The good thing is that the bulbs are shorter, so they do not hit the shield. This is my first time using their products, but I ordered 3 sets of 35w HID lights. My brother in law has been using their HID lights for over a year without any complaints. I thiought I would give them a try.
http://www.ddmtuning.com/products/101/
#32
Anyone know exactly what LED lights he has in the side step, license plate and Im guessing the LED for the turn signal bulb (is that the DRL as well) There are several choices for the LED's Im seeing on the VLED site
#33
On Xenon depot site they have Putco LED's--I see the GX takes a few 194 bulbs and they offer 2 styles---which ones do you go with
http://www.kbcarstuff.com/194-LED-Re...hite-s/588.htm
#34
VINCE22
I was looking at my GX and yours, it looks like you have the LEDS in your parking lights? If so in your pictures you GX is NOT running cause if it were (like mine) your Yellow turn signal lights would be on as well--correct?
If it is running why dont your yellow turn sig bulbs stay lit up?
#36
Yo LZ,
Sorry to reply to an old post.but I've combed the internet with no luck changing the running board light on my 08 GX470.
Tonight I went underneath the running board to see how the heck am supposed to change the running board lights. What I saw below was astonishing. I can't even get my hand to where the bulb is or see the bulb. It seems as if I would have to unbracket the entire assembly to get to the bulb. Is that the case ?
Can you please share some wisdom on how to please accomplish this.
Thanks
rbx10
GX470
Thanks
rbx10
GX470
you will have to lay down some cardboard or something and lay down on your back and literally slide your head and shoulders under the car to get a good look at what you're working on. the light assemblys are on the the ends of the runners. literally near the tires(on the ends of the boards) there is no need to remove them(the running boards/steps) to do a simple bulb swap. my vehicle is an 06, i doubt that they changed the design on the 08. i may be wrong but i doubt it.
#37
You mentioned that you purchased a HID relay from HIDExtra. The relay aren't part of the package? Was it just for the high beam?
Thanks.
#39
#41
Problem to wiring h3 hid on my gx470
Can anybody me show me how to wire the h3 hid to my gx470, because I wire the hot wire to factory harness but the black wire to that harness also. But I try reverse 2 time or black wire from the bulb connect to factory ground wire too. I just wanna make sure I wire the right way with defective product or I wiring a wrong way, maybe do I need relay for that kit, if anyone know can me please!
#44
#45
cause the factory bulb come in one hot wire and come with little ground wire tap in to the bulb get ground but the h3 hid bulb has 2 wire 1 red 1 black, I hook up hot wire ground wire to factory harness, either I did a reverse still doesn't work, I been play with this for 2 week. The kit got it from hidnation so rule
