CD case & navigation
![Cool](https://www.clublexus.com/forums/images/icons/icon6.gif)
hello every one this is my first time post, i have 2005 GX 470 my cd case did not reject is stuck . did any one have same problem ? and how to fix.
also did any one know how to up date the navigation ? any help would be appreciate.
kha
kha
KEvin, I had recently had this problem, the main cause is as per the dealer that any non standard CDs which we burn at home and compile music being our favourites should not be played ( that any CD-R ) using various burn softwares. I have acquired the TSB, the CD tray was the culprit, I had that removed by removing the unit and having the tray replaced. I have been using for last many years, but never I have ever heard that Toyota would come with such description that these should not be used. SO i assume you can get working to removed the tray unit and have it opened out and check it functionality, if still u/s then have the tray magazine replaced, only cost 50-75/- bucks than replacing the whole unit.
Thank you how did you removed the tray,did you did by your self or you have the store did ? Have you been up day the navigation? Please let me know . Thank
I have a 2005 GX470 i upgraded my navigation disk to a 2009. it cost me 119.00 pull the right front seat all the way foward under it. is the navigation pull the disk out and put the new one in it upgraded it self.
aneidiaz
01-26-16 10:44 PM
jnat306bg
GX - 1st Gen (2003-2009)
06-24-13 01:51 PM
LexusDaisy
02-13-04 09:51 PM
