Here's How To change Front Right turn signal bulb (with photos) in your Lexus GX470
#106
Just tried changing out the drivers side front turn signal bulb (in front of the battery) and it wasn't as easy as it sounds in this thread!
After about an hr. of prodding and twisting/turning I was finally able to replace it! Works great now![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
So just wanted to come back here and see what I missed..... or why no one else seemed to have any issues replacing the front bulbs... and bam - that little tid bit about getting "under the vehicle with a crawler/creeper" - totally missed that![Egads!](https://www.clublexus.com/forums/images/smilies/pat.gif)
Yeah, doing this from the top of the engine compartment.....without removing the battery.... NOT EASY. I was able to get the bulb out but inserting the new one and then twisting/turning it into place was not easy. Not much give in the wires so my left hand is now scraped up pretty good
#107
Ya, it's easier to access from the bottom. Because the bulb it located more than 2 feet from the ground it helps to lie on a board propped up with a couple of 2x4s.
Good on you for getting it done!!
#108
I did both of mine from the top. The right side was tighter and needed a pliers to grip and turn. Drivers side twisted right out. I have medium sized hands so it wasn't too bad.
What I would do different today if one went out is get the two pack of bulbs and replace both at the same time. Keep the good bulb in case of an emergency failure.
#109
Hi all, I wanted to give you this quick tutorial on how to change the front right turn signal bulb for your Lexus GX470. There's a lot of back and forth on the forums, with people adding way too much confusion, so I wrote this guide with photos for you so there is no mistake. This will take you less than 5 minutes.
My tips apply to my 2004 GX470. They may or may not apply to your year, and you better verify the correct bulb for your vehicle, don’t just go by what I have here.
First, many people are telling you to waste 20 minutes undoing the plastic shield around the engine compartment and work from above. NOT NECESSARY! You change the light bulb easily from below in a few minutes!
Warning: Always bring your bulb with you to buy a new one! Many auto parts stores online, when I looked up the part, show an incorrect 3157 part number, whose bulb does not even look close to being correct. Always trust what you know.
The turn signal light bulb you need for a 2004 Lexus GX470 is called 1156A
it is a standard bulb, amber in color, most auto parts places sell it. I bought my bulb, shown below at Pep Boys, 2 bulbs for $3.99. Forget paying the dealer $50-$100 for this job that you can do in 5 minutes. Note how the bulb in my package has the letters “LL” at the end. IT means Long Life. If you can get this designation, go for it.
![](https://i.imgur.com/JDaQKMF.jpg)
Now you can see the close-up of your bulb below. Notice it has 2 little nipples on it, this means it will slide down a channel in the connector, then twist at the bottom to lock into place.
![](https://i.imgur.com/hEnkDZB.jpg)
How to change the turn signal bulb:
1) Lie down on your back just underneath your front right bumper, below the headlight. I just rested my head on a mover’s dolly. Now look up behind the headlight assembly, as shown in my photo below, and you’ll see 3 connectors on the back of the headlight assembly. You will focus on the gray one in the middle as shown in the photo here:
![](https://i.imgur.com/QsQjCyg.jpg)
2) Reach up toward that gray connector, your arm will be reaching up a bit. The connector has winglets for you to grasp it. Now grab that connector, and twist it counterclockwise about 1/4 turn until it loosens, then pull out the connector as shown in this photo below:
![](https://i.imgur.com/rTbwGWp.jpg)
3) There’s your turn signal bulb! Now twist the bulb first, THEN once you have twisted it loose, you may pull it out of the socket. If you find it hard to hold the socket while twisting the bulb loose, then use pliars or Robo Grips to hold the socket steady, then use your other hand to loosen the bulb.
![](https://i.imgur.com/yDpdnL7.jpg)
4) Now here is your loose socket hanging. That’s my flashlight on lower right corner of the photo:
![](https://i.imgur.com/sHQm66M.jpg)
Here is another zoomed out shot of the socket hanging down:
![](https://i.imgur.com/8RVKGEu.jpg)
5) Now take your new bulb, and align the little nipples on the bottom of the bulb to the channels on the connector. Then slide the bulb down the into the connector, and twist the bulb clockwise to lock it into place. Now reach up to re-connect the bulb and connector back onto the rear of the headlight assembly as shown below:
6) Now insert the bulb back into the hole on the rear of the headlight assembly, and twist the gray connector until it’s all locked into place. That’s it, you’re done! See photo below:
Now wasn’t that a lot easier than undoing a bunch of plastic fasteners in the engine compartment? Congratulations, you just saved yourself at least $50.
Now PayPal me $10 of that! LOL!
I’ll open up the floor to questions now.
Jeff
Jeff
#110
Amazing write-up, great video, 5 minute job.
One thing, I upgraded to LED, but had to disconnect my DRL to avoid the burning. I used a different thread from here to do that.
I bough built in resistor LEDs from my go-to LED bulb company SIRIUSLED. No hyperfalsh, and it is quite the upgrade (although I would like to have the DRL honestly). I even used their built in resistors for the rear, and all 4 no hyperflash! Looks amazing.
Love this forum!
#111
So...ideas on how to change the side marker bulbs? My ‘08’s socket looks nothing like the one in the only YouTube video I found. I’ve never seen this sort of socket before. I couldn’t figure out a way to remove it from the housing.
#112
It’s definitely a pain, but 100% doable from below.
https://www.clublexus.com/forums/gx-...nt-thread.html
![](https://cimg3.ibsrv.net/gimg/www.clublexus.com-vbulletin/580x387/17195326_c39d_4ac6_aaf6_e9b9c07b4ae2_0ef6d074ecd1ebcbf0c78cea7dbf3ce2414b5e86.jpeg)
#113
started keeping track of how long these 1156NA LL bulbs last, being on all the time...i have replaced them every october for the last 3 years....I get one year out of the bulbs...when I take them out they are faded and cloudy.... obvioulsy milage has nothing to do...its time just time....what a pain....
#114
https://www.clublexus.com/forums/gx-...l-disable.html
I did this, and upgraded to full LED bulbs everywhere and couldn’t be happier.
zippinbye
GX - 1st Gen (2003-2009)
11-23-20 03:41 PM
