Towing Suggestion
I've never towed before but I'm getting my 18ft Travel Trailer delivered in the next few days. It's empty weight is about 2700 lb, with a sway stabilizer included in the hitch. I'm going to use my 2006 GX470 for the job. I've read that I shouldn't drive with the overdrive on, keep the suspension to firm and not to drive with cruise control. I'm looking for other suggestions from anyone with towing experience and any GX470 specific hints. It has the Lexus 6500lb Hitch installed.
Thanks
Thanks
I towed 3650 lbs Jayco Feather Lite 22 Feet, in drive when it was flat. I had no problem once I hit the minor elevation I switched to 4 as elevation icreased I switched to 3rd gear. Defianetly do not use cruise control. Also do you have brake controler?
Thanks
Thanks
Does anyone use a Weight Distribution Hitch with their towing, wasn't sure If I needed it with the Lexus active suspension?? And does anyone change their differential and transmission oil regularly due to towing??
Thanks
Thanks
My hitch originally had a a 3" drop and that was to low, so the trailer would not sit level or in other words it would slant towards the front despite that my truck was level. Turned the hitch over (now have a 1.5" rise) and put the ball on the other side and that did the trick, trailer sits level now.
Tip: Lower your suspension to hitch up and disconnect. That way you don't have to crank/raise the trailer jack nearly has high.
empinball
GX - 1st Gen (2003-2009)
08-06-19 08:46 AM
