Grinding sound when car is in drive and trying to accelerate.
Hi,
I ger this grinding sound when I put the truck is drive or reverse and the truck goes nowhere. I ran into this problem over the weekend when I had a valet attendant park the truck. I tried everything I can to get it in gear including yanking the H/L shifter as hard as I can but ended up having to flatbed the truck to the dealer. They are now looking into the problem. I am afraid they might come back and tell me I need a new transfer case or transmission and it's going to cost me over 5k. I have a 2004 with 40K miles and it's over 8 months out of warranty. Do you know what might have caused such a problem?
Thanks.
Thanks.
my guess is the valet did some serious off-roading for you
j/k
in all seriousness, I'll be they moved the H/L xfer case while the truck was in gear and/or moving. Hopefully it's just as simple as putting it into N and shifting it back to L, then to H letting it cycle thru. Let us know what they tell you and good luck!
I just got a call from the dealer, they said that the transfer case needs to be replaced and it's going to cost my 4300 for the parts plus labor. I don't understand how something like this can break all of a sudden! Could shifting the H/L lever while the truck is running cause such damage?
At this point I am running out of options. I know these truck's were having problems with a leaking transfer case. Mine never had the leak but could the whole transfer case be defective?
Take your car to any Independent Lexus shop. Can you rebuild it? Also check car-part.com may be you can find used one. Also tell dealer that Transfer case was deffective may be they can help you with the cost.
aer6438
RX - 1st Gen (1999-2003)
20
05-09-15 06:05 PM
Hbhandal
10-21-13 10:18 AM
Blue1991
05-14-09 12:40 PM
