new 22's, now shimmy.
I have a shimmy motion in the steering wheel at highway speeds only between a certain window of speed. Is this a balancing issue? Alignment? Or did a problem just get magnified due to the weight of the wheels.
if it is at higher speeds it is balancing, if you had a out of round or centering issue it would be more noticable up 40-50mph i would get them balanced and if that fails look for someone with a road force machine. because the aftermarket wheels have high and low spots that should be matched with the tire
If your rims offset is anywhere above 45 that is when it will effect your toe. Most aftermarket wheels that fit are either going to be a 108MM Hub or 110mm. If the wheel fits in perfectly then it is a 108MM and more than likely a balance issue. If it is 110MM, it may be because of that but is still a balance issue unless you have what is stated above for offset. Depending on how long you had the rims on, are you seeing signs of wear on the tire?
That doesn't mean that a different offset or tire-width won't exacerbate drivability issues relating to toe being off of spec. It might. Just wanted to counter the notion that wheel offset had anything to do w/toe.
Toe is simply:
- distance between (left and right sides of the car) the rear edges of the wheels, minus
- distance between the front edges of the wheels
If positive, then "toe in"
If negative, then "toe out"
Minor point: Wheel offset doesn't affect toe.
Toe is simply:
Toe is simply:
The gx has a 108mm hub, right? So if the rim has a 108, then its an ideal fit? What if its off by 1mm? Can I get rings that thin?
Do you still have the orig rims? if so, put them back on and go get the alignment. Then bolt on the new rims. The rims have nothing to do w/the alignment.
Toe is a measure of whether or not the wheels on a given axle are “pointing” in the same direction. Zero toe means they’re both pointing exactly forward. Toe “out”, means just that. Imagine twisting your feet such that your toes point slightly “out”. Toe “in” is the opposite. Toe settings can definitely affect how well a car tracks; especially on uneven/crowned surfaces.
108mm Hub Bore. That I know of, there are only two sizes that manufacturers use 108 and 110mm. If you happen to come across a 107 Hub, it will be tight getting it in. This is one of the dilemma's of finding rims for this vehicle. It shares the same bolt pattern as a silverado, Armada, and most popular SUV's (Excluding Dodge and Ford) but the hub bore is the limiting factor. You can use adapters but the lowest you can get is 1.25". That puts another 31mm to the offset. Using a 1" will have a clearance problem with the bolts. Overall, the choice is yours but there are rims that can fit without using a adaptor.
