Trans fluid
Old 09-12-10, 09:52 AM
pjarvis
pjarvis's Avatar
Default Trans fluid
I've always used Royal Purple in my engines. The dealer is not sure on the tranny,it says Toyota type 3&4 0n the RP quart container.Has anyone used, or can somebody confirm if this is the right thing to do?
Old 09-13-10, 08:48 AM
JohnJerk
JohnJerk's Avatar
I thought all years of the GX used World Standard (WS) trans fluid. No idea if Royal Purple offers WS. Your dealer should be more than certain on what to do!? IMHO avoid all but the factory stuff.
Old 09-13-10, 10:16 PM
mann777
mann777's Avatar
The Toyota Trans fluid WS does not need replacement except topping up at intervals, as these liquids lasts for the life of the vehicle, and toyota does not receommend replacement of the WS.
Old 09-14-10, 08:43 AM
Koz
Koz's Avatar
If there is no dip stick the trans requires no maintenance. It uses WS fluid. The only other fluid (besides OEM) that can be used is this;
http://www.amsoil.com/storefront/atl.aspx
Koz
Old 09-14-10, 05:40 PM
cssnms
cssnms's Avatar
Unless you tow or do lots of off roading I would leave the WS fluid alone esp if your trans is still under warranty.
Old 09-15-10, 05:43 AM
Lexmex
Super Moderator
Lexmex's Avatar
The WS fluid is pretty robust. I have a 2006 4Runner V8 (identical motor to that in the GX) that my girlfriend drives but when it comes time to change out the tranny fluid, I will still be looking at the possibility of using the Amsoil ATL fluid Koz mentioned. I am not aware (and just checked) of any Redline or Royal Purple ATF that satisfied WS requirements, though I do use Redline D4 in my RX300 which satisfies Type IV requirements and had previously used Amsoil's Synthetic Universal which also satisfies Type IV requirements. While Redline and Royal Purple have Type IV equivalents, again they have not come out with a WS equivalent fluid.
Old 10-15-10, 04:09 PM
LMcCadden
LMcCadden's Avatar
470 gx brakes repair
Michael
13
11-24-13 08:59 PM
kmoore737
Performance & Maintenance
11-20-12 09:43 PM
Mike
RX - 1st Gen (1999-2003)
12-09-07 11:23 PM
HotBoy
Maintenance
12-30-03 09:09 PM
Japanimal
07-24-03 07:22 PM
Quick Reply: Trans fluid
