steering wheel vibration 65-70 MPH
Thanks, Smitty. Takes getting used to, But i like them too. LUKE27617, Sounds like front wheel bearings if the balancing didn't work as posted by someone else.
Im getting the vibration again at the same 60-65 mph speed. I'm thinking wheel bearing at this point as others had replaced. Is there a way to check for a bad wheel bearing before replacing? I have an aftermarket warrnaty but dont want to pay a deductable for something that dosent cure the problem.
Seems like the majority of bad wheel bearings are from the drivers side. Also unrelated I get clanking going over bumps but the clanking goes away if I apply my brakes over the same bumps. I did recently have 2 new calipers installed in the last 6-8 months, Any thoughts?
I was thinking caliper clips as well. Same thing here new calipers and rotors/pads. Something is loose.
There could be several differ reasons why you are experiencing vibration. When I replaced my tires, I started to feel some mild vibration around 65-70 mph. I thought it was due to the wheel balancing. I asked them to only install compensating weighs on the inside of the wheel, so that there would be no ugly weights hanging on the visual side (outside) of the wheels. The wheels balanced fine in free air on the machine. But when you are driving your tires are not in free air (at least not most of the time). So it could be road force variation. There may be slight tire imperfection during manufacturing that may result in “hard spots”. These “hard spots” can cause vibrations, even if the tire is balanced. Find a tire store equipped with a Hunter GSP 9700 road force balancer or similar.
Did this fix the problem? It's driving me crazy, some days are worse than others. My vibration even gets more prevelant when braking while doing 65 mph. I have new rotors and brakes and the vibration isnt in the brake pedal just the steering wheel. Im bringing it in when i get a chance. It must be a wheel bearing or drive shaft issue. Anyone?
Hi to all,
I'm new to GX world and too new to your community to even post any attachments with my reply. I also have the vibration between 55 and 75 mph speeds and I can feel it in the driver's floor board and low/high transfer case shifter.
Did you ever see TSIB # DL001-08 about front differencial dynamic damper?
I believe my 03 didn't have the right one on since day one and there was revision made in 2004 with TSIB ST004-04 for replacement.
Hi to all,
Hey Rosco,
I had my wheels replace at Costco. On the original wheels though, the weight were set on the outside of the tires. However since I was looking for a cooler look, I asked Costco to put them in the inside. The guy warned me though that I could experience vibration when I reach 65-70 mph. Well guess what ? He was right on the money. Right I seem to experience the same thing you are. After my rotation, the steerign wheel does not seem to shake as much as before. I just might go back and have them put the weights outside.
I just can't stand the look though man
Good luck.
rbx10
Good luck.
rbx10
