Towing O7' GX470
Old 10-06-10 | 04:46 PM
RReeves's Avatar
RReeves
Default Towing O7' GX470
Anyone towing on all four?
Old 10-07-10 | 11:12 AM
cssnms's Avatar
cssnms
What do you mean by "towing on all four?"
Old 10-07-10 | 11:18 AM
mann777's Avatar
mann777
I think maybe reeves meant was AWD and tow.
Old 10-07-10 | 12:16 PM
redrocks's Avatar
redrocks
?? AWD ?? Permanent 4WD, right? 4WD with differential locked in and towing?
Old 10-07-10 | 04:00 PM
RReeves's Avatar
RReeves
I meant flat towing the GX470 behind a motorhome.
Looks like it can be done. The owners manual says not to.
I have found a few posts here from guys towing their GX 470's and I was hoping to hear from a veteran RV guy doing it.
Thanks
Old 10-07-10 | 06:46 PM
redrocks's Avatar
redrocks
That must be some big motorhome to haul almost 5,000 pounds! I guess you would put in neutral, right?
Old 10-09-10 | 08:26 PM
HaveBlue's Avatar
HaveBlue
If you do decide to tow it, I would recommend starting the motor at every gas stop and running the tranny through all gears for a few minutes to lubricate the seals. The AT will be the vulnerable component in flat towing. I don't know how sensitive it is but the A750 is a continuation of previous 4Runners. Everything else is self lubricating.
JakSiemasz
GX - 1st Gen (2003-2009)
12-06-07 02:40 PM
caryt
05-02-05 04:20 PM
thurstonh3
07-02-04 05:40 PM
