Auto Tilt Reverse Side mirror issue
Old 09-20-13, 09:16 PM
rbx10
rbx10's Avatar
Thanks all for your reply. I will try the SimSimGX spray fix when I get some times.
rbx10
Old 09-20-13, 10:02 PM
Booyah
Booyah's Avatar
Its very easy to replace the motor in the mirror! I have a write up on it as I did it in about 45 minutes..
Old 09-21-13, 05:33 AM
RCsGX
RCsGX's Avatar
....the link is below for anyone needing it.
https://www.clublexus.com/forums/gx-...-up-picts.html
Old 09-24-13, 07:00 PM
rbx10
rbx10's Avatar
Originally Posted by SimSimGX
I just finished fixing both mirrors on my `08 GX. Total cost = $12 + 2 hours work.
I`m a pretty handy guy so if you`re not capable of handling a philips screwdriver and electronic connectors, please do not try this.
I bought a can of `Electronics Contact Cleaner` for $12 at my local electronic supplier. Took the whole thing apart with the aid of the TSIB provided by lexus (Attached PDF file). NOTE: You do not need to disconnect the battery during this procedure; however make sure your car is turned off the whole time you`re working on this.
I used the Contact Cleaner and sprayed every electronic component I found inside the Actuator, greased the plastic parts and put it back together.
My mirrors are now working perfectly fine
Good Luck!!
Hey Sim,
What's the name of the white grease you use please ?
Thanks
-rbx10
Old 09-25-13, 08:19 AM
RCsGX
RCsGX's Avatar
Originally Posted by rbx10
Hey Sim,
Thanks
-rbx10
White lithium grease.
Old 09-25-13, 06:03 PM
rbx10
rbx10's Avatar
Thank you very much RCs. I should be able to find this grease at Pep Boys.
-rbx10
Old 03-16-17, 04:22 PM
Listers
Listers's Avatar
Good Luck!!
Your only post on this forum has probably helped me out. My passenger side mirror sometimes doesn't return to its neutral position when transmission is in D. I will try this since I already have contact cleaner on hand.
Old 04-16-18, 11:32 AM
subspd
subspd's Avatar
The images are all broken in the links. Anyone have pics of replacing the actuator?
Also when you all are talking about cleaning the contacts are you talking about the interior switch or the window actuator?
Old 04-16-18, 12:46 PM
ALAN553
ALAN553's Avatar
pics and instructions come with the part...it’s a 10 minute repair. Did it many years ago
is250fsprt
03-13-14 06:05 PM
danmm7
GX - 1st Gen (2003-2009)
10-01-12 02:11 PM
DarkknessD
09-05-10 08:34 AM
vpalacio
18
05-12-07 03:13 PM
lonewolf69
20
12-16-05 08:10 AM
Quick Reply: Auto Tilt Reverse Side mirror issue
