Do I need to replace the rotors?
Old 04-03-11, 05:57 PM
mansito
mansito's Avatar
Default Do I need to replace the rotors?
At 83K miles there is ~3mm left on the factory front brake pads on my wife's 05 GX470. The truck brakes smoothly, that is, there is no pulsation on the brake pedal when the brakes are applied. I am planning to replace the front and rear brake pads this coming weekend.
Is it OK to just replace the pads using the existing rotors? If there was pulsation I would definitely replace the rotors.
Old 04-03-11, 07:10 PM
ALAN553
ALAN553's Avatar
If they can be resurfaced and still have enough thickness,why replace them?
Old 04-04-11, 04:21 AM
mansito
mansito's Avatar
I do not want to resurface/cut the rotors because, base on all the comments I've read on this forum, they will warp quickly. If I have to cut them, I may as well get new rotors.
Old 04-04-11, 04:39 AM
cssnms
cssnms's Avatar
Measure for thickness if they are within the acceptable tolerances and there are no other signs of physical deformity, old pads wore evenly, no pulsing etc no need to resurface or replace the rotors. Just make sure to bed the new pads in properly, which will also help to remove any glazing on the rotor surface.
Old 04-04-11, 08:54 AM
ALAN553
ALAN553's Avatar
well that may be what the posts say, i replaced front pads at 25, 50, 75 and 107K, the rotors were resurfaced the first three times and just replaced at 107,000. I had no problem the first three times, no vibration at high speed braking. so...your call, rotors aren't that much anyhow.
Old 04-04-11, 03:57 PM
mansito
mansito's Avatar
Thank you guys.
Old 04-10-11, 08:05 AM
MWalker
MWalker's Avatar
Where can one purchase, and how much should a set of front rotors run?
Old 04-10-11, 08:09 AM
cssnms
cssnms's Avatar
OEM rotors can be purchased from a Toyota dealer for considerably less, they are the same rotor found on the Toyota 4-Runner V-8. Also try Sewell http://www.sewellparts.com/
I have not had favorable experiences with aftermarket rotors to include Brembo blanks and PowerSlot Cryo rotors.
Old 04-10-11, 12:16 PM
snhrph
snhrph's Avatar
It is perfectly OK to replace the pads WITHOUT resurfacing or replacing rotors. Based on your description, there were no problems with brakes, so just replace the pads. As the old saying goes: "Don't fix it if it ain't broke".
Why resurface the perfectly fine rotors? No pulsation = no rotor warping...
Completely agree.
You'll be surprised how good the brakes are on your GX with proper bedding the new pads.
Old 04-11-11, 04:00 AM
mansito
mansito's Avatar
Or just go to Autozone. Their parts have lifetime warranty. If the rotors warp, you bring them back and they will replace them. Make sure you save your receipt.
Old 04-11-11, 04:35 AM
mansito
mansito's Avatar
Replaced the brakes during the weekend. Found a frozen piston on the driver sider front caliper. Used Autozone Cmax pads (front + rear) and Autozone caliper. The work of replacing the pads + caliper if very straight forward. After the pads were installed, I followed the process for bedding the pads. Everything works very nice. Braking is good + no pulsation or pulling.
Old 04-14-11, 07:28 PM
ROSCOGX470
ROSCOGX470's Avatar
I used the Cmax pads with drilled/slotted rotors. They seem much better however not sure if I need to "bed" them in. If Im not mistaking I believe its like hard stops from 60mph-5mph 6-8 times twice....Does this sound about right? any mechanics out there in favor or opposed to the "bed" in process. Ive never done this before in the past and never had a problem. Also with drilled/slotted is it required? Sorry- not trying to hijack the thread just curious.
Old 04-14-11, 07:33 PM
snhrph
snhrph's Avatar
This was discussed at length in several threads on this forum, try searching...
Link below will outline the process for you:
http://www.zeckhausen.com/bedding_in_brakes.htm
Old 04-14-11, 07:38 PM
ROSCOGX470
ROSCOGX470's Avatar
I have read that article. My question is does having drilled/slotted change the dynamics of the bedding in process or does it apply to drilled/slotted as well?
Old 04-15-11, 08:13 AM
snhrph
snhrph's Avatar
http://www.stoptech.com/tech_info/wp...formance.shtml
Spam89
RC F (2015-present)
14
07-31-18 12:09 PM
aumate
RX - 3rd Gen (2010-2015)
12-07-16 10:42 AM
YWW
03-18-15 02:13 PM
peehole813
Suspension and Brakes
10-10-10 02:02 PM
DaveJ
10-12-07 01:05 PM
Quick Reply: Do I need to replace the rotors?
