lockpick not working after nav 10.1 update
i have a 2005 gx with the coastaltech lockpick...it has worked flawlessly for the last 6 yrs, but now after the 10.1 update i cannot enter in the address while in movement. anyone have a solution for this? i contacted coastaltech and just waiting for a response, but just wanted to check in if anyone else has run into this problem..i cant wait till mon or tues for them to get back.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
The override menu has been removed for the last few nav update releases since v5.1.
Coastaltech doesn't have any solution that I've found anywhere, nor has there been any successful 'hybrid disk' for Gen 4 with 10.1 that I've seen which would allow you to use the map data from 10.1 with the nav software from 5.1
I had the same issue in my LS with lockpick and chose the updated maps over the override.
Forum Administrator
Got lockpick also and its working fine, just uploaded a video as proof. check link below. Goodluck.
http://s975.photobucket.com/albums/a...pick_gx470.mp4
Can you do a quick video of it going through the override menu (once you push the little bullseye pushpin?)? Did you create a hybrid nav disk?
Dave, no hybrid disk used, it stay as long as you want with no speed limitation, just straight up lockpick, entering address and phone numbers on screen while in motion.
Forum Administrator
So odd, because the override menu does not exist in version 10.1 as far as anyone has found.
Would you mind doing a short video of pushing the lockpick bullseye and letting it run through the override?
