Sunroof Rattle/Tranny Slip
Old 07-05-11, 11:11 AM
GXM35
GXM35's Avatar
Default Sunroof Rattle/Tranny Slip
Took vehicle in for two things last week and they said both were normal for the vehicle.
1. Sunroof rattles. I can physically push up on the sunroof and feel a little play in it. It doesn't leak or anything, but does rattle on certain roads. Dealer say it's tightened to standards and within normal expected specs for the age of the vehicle (2007), but after feeling the sunroof in my other car that has no play in it whatsoever, I'm a little skeptical. Anybody else with this?
2. Under certain conditions, the tranny seems to slip/pause and then grab a gear. It happens on off-ramps usually. I let off the gas to slow down and the give it gas to carry me through the off-ramp. It feels like a clunk or the tranny slipping trying to find a gear and then it finds one and noticably clunks in. Dealer hooked up a computer to it and it says it's operating noramlly and the clunk is just a product of the way I drive and the electronic shifting computer. I've had my drive shaft replaced thinking this was the problem, but it's still there. Any one else?
Old 07-05-11, 05:06 PM
redrocks
redrocks's Avatar
Rattle in a sunroof on vehicle 5 years old is not normal. I've had one vehicle with over 200K miles with no sunroof rattle. Had another vehicle with 137K with no rattle. Currently have an Acura with 155K, no sunroof rattle.
The RX330 had a known issue with sunroof rattle and Lexus corrected this. Not sure whether the GX has issues with the sunroof. A search of the GX forum shows some folks have had issues with the sunroof rattling.
Old 07-06-11, 07:54 AM
cdew002
cdew002's Avatar
I've had a few cars do that when I'm going down hills and push the gas pedal. I'm pretty sure it's based on how you (and I) drive.
Old 07-06-11, 09:50 AM
GXM35
GXM35's Avatar
I wouldn't think a loose sunroof when closed would be normal on a vehicle like this. Maybe on a '76 Firebird.
Old 07-06-11, 09:52 AM
GXM35
GXM35's Avatar
It normally shifts fine. It's under a certain circumstance that it happens. As long as it's not hurting the car...
Old 07-06-11, 09:55 AM
Booyah
Booyah's Avatar
No sunroof rattle on mine either (25K)--something is not right with it. Can you produce the sunroof rattle at all times, if so take the mechanic with you and let him here it. Shifting sounds ok, its the way you are attacking the ramps lol...try a differant way? and I bet its fine
Old 07-06-11, 12:59 PM
Jameym00
Jameym00's Avatar
My land cruiser has what your talking about. A lot of play and noise but no leak and no way to fix it either.
Old 07-06-11, 03:05 PM
GXM35
GXM35's Avatar
Easy to produce. Just push up and down on it. You can see it move and hear as well
Old 07-06-11, 03:06 PM
GXM35
GXM35's Avatar
It's like it's missing a strip of rubber or a shim or something.
Old 07-06-11, 03:25 PM
cssnms
cssnms's Avatar
The sunroof on my 2005 is tight, no rattles.
I have on rare occasion experienced the transmission clunk
That you describe. Like you, its usually when I decelerate quickly from say highway speed, then immediately try accelerating again, like one would at a highway turn off. Don't think its anything to be concerned about.
Old 07-06-11, 03:34 PM
GXM35
GXM35's Avatar
Thanks. Gotta get the rattle fixed...
Old 07-09-11, 02:33 PM
lonbon
lonbon's Avatar
Cool
Buy some silicon spray lube, tilt the sunroof, wipe the rubber surfaces and metal contact areas with a rag coated with the lube. Partially retract the sunroof and do the same to the front side. Plan to do it again next month.
That is the only way I have been able to eliminate the noise. On one of the Toyota 4 Runner forums, there is some sort of plastic bushing fix, although I have not tried it. If it is any comfort, I have had several Acuras and they all made noise. On one, I had to lube with vaseline every 2 weeks.
Old 07-10-11, 11:34 PM
Pearlpower
Pearlpower's Avatar
Both not normal. At times when it is hot, the clutch fan licking in sapping a little power might give the impression the vehicle is working harder cause it is, but I beat the hell out of our GX off road and on, no slippage-never.
Old 07-11-11, 05:53 AM
cdew002
cdew002's Avatar
Another instance of the tranny "thing" is in my wife's RX330. When she drives, it never misses a beat, but if I drive, I cause the same issue the I get with my GX.
Old 07-13-11, 09:14 AM
Vinniety
Vinniety's Avatar
I was going to say if your coming off an exit around a bend and its happening maybe and again just maybe your low on fluid BUT you posting it also happens in your wifes rx then its YOU!!!!
Quick Reply: Sunroof Rattle/Tranny Slip
