timing belt.. backwards?!?
My mechanic (also my Brother - certified dodge mechanic) says he might have put timing belt in backwards (as in the side that is supposed to be facing left, is facing right and vice versa). I dont want him to have to do the whole job over again unnecessarily.
Anyone know what the symptoms would be, if any? I do have the codes P0016, P0018 (Camshaft position sensor and crankshaft position sensor correlation) and of course a check engine light. Otherwise the vehicle is running great, no timing issues that I can notice.
Thank you!
This is a 2006 GX470 4.7L V8 2UZ-FE engine.
Thank you!
Dysfunctional Veteran
A timing belt is a timing belt...doesnt really matter which way it goes on. Whats important is that the timing is correct when its put on. Have to line up the marks on the cams...
Valencya01
Maintenance
10-30-18 08:02 AM
