NEW clunk please help
Old 08-04-11, 10:05 AM
matts04gx
matts04gx's Avatar
Default NEW clunk please help
Hi,
I just purchased a 2004 GX with only 45K miles and I love the truck. I have driven one with the TSB clunk and my current problem is different. When I stop at a light and go to start driving again I feel a thud when I take my foot off of the brake. There is no problem when I stop just when I go to start again. Is this a serious problem or normal?
I talked to Lexus before buying the truck and they said that the TSB fix had been repaired.
Thoughts?
Thanks for the help.
Old 08-04-11, 11:46 AM
ALAN553
ALAN553's Avatar
Originally Posted by matts04gx
Hi,
Thoughts?
if the repair was done than there is a record of it at any Lexus dealer, because it sounds like the good old driveline clunk
Old 08-04-11, 02:18 PM
matts04gx
matts04gx's Avatar
Alan,
I thought the old one occurred after the vehicle came to a stop? I can stop for any length of time and nothing happens. This only occurs it when I let off the brake and begin to hit the gas.
Matt
Old 08-04-11, 02:38 PM
gordie
gordie's Avatar
Matt,
My '05 (80K miles) does the same--slight thump when accelerating from stop but not when coming to a stop. My driveshaft was "repaired" according to specs in '05 which are now different so the original "fix" seems effectively nullified. However, I didn't own the truck then, so I don't know how bad it was at the time.
The current thump is so subtle that I don't plan to do anything about it. I'm out of warranty and so many people report a rougher ride post clunk fix that it doesn't seem worth it to me. My ride is quite bouncy as is, so I certainly don't want it to get worse.
That said if anyone knows the cost to repair the driveshaft per current specs, out of warranty, I'd like to know. Also, please chime in if I'm doing damage to anything by living with this very minor clunk (not even positive that's what it is, but I assume so).
Old 08-04-11, 07:01 PM
ALAN553
ALAN553's Avatar
I think I saw the new drive shaft on Sewell for less than 300, it's only 8 bolts, a private shop shouldn't want more than maybe 125 to replace it and lube it, only takes 1/2 hour
Old 08-04-11, 07:10 PM
ROSCOGX470
ROSCOGX470's Avatar
Not too bad. Also a sticky caliper could possibly mimick the clunk.
Old 08-04-11, 07:30 PM
Jameym00
Jameym00's Avatar
Try to put grease in the grease fittings. The shaft and the ujoints have them.
Old 08-04-11, 08:24 PM
snhrph
snhrph's Avatar
Definitely do that. But be careful when greasing the u-joints, you don't blow the seals.
Splines, on the other hand, will take a LOT of grease.
While under the truck, inspect the motor and transmission/transfercase mounts. I doubt that there is anything wrong with them, but just to be safe...
Old 08-05-11, 11:20 AM
matts04gx
matts04gx's Avatar
Thanks for all the help. I think I am going to have the dealership look at when I get my next oil change just for piece of mind.
real84
GX - 1st Gen (2003-2009)
01-11-13 05:25 AM
ichigo13
ES - 5th Gen (2007-2012)
11-09-10 12:07 PM
cannga
19
01-31-07 07:30 PM
LexusStevo
06-30-06 03:18 PM
TexGX
31
12-03-05 12:01 PM
Quick Reply: NEW clunk please help
