Need Help ASAP lights and check engine on???
Old 08-26-11, 05:39 PM
bayer96
bayer96's Avatar
Default Need Help ASAP lights and check engine on???
I was driving my car in the afternoon today and noticed the VSC TRAC, VSC OFF, and Check Engine on at the same time? I am worried what is this anything in the powertrain I really love my lexus and I am scared not to screw anything up please help thanks....
Old 08-26-11, 06:55 PM
tz693
tz693's Avatar
Read this https://www.clublexus.com/forums/gx-...-replaced.html.
You may end up with the same problem.
Old 08-27-11, 08:38 AM
BurgBoxstr
BurgBoxstr's Avatar
yes it could be an O2 sensor but it could also be a loose gas cap, bad coil pack on one or more cylinders, bad MAF, a vacuum leak, etc., etc., etc. Lots of possibilities... W/o the specific error codes they're all just guesses and you could end up throwing lots of good money replacing perfectly fine parts.
So... go to any national auto parts chain (AutoZone, Advanced Auto, Pep Boys, etc.) and have them read your codes w/ their OBDII scantron (most/all do it for free). Then post back here w/ the results. Ask them for the specific codes (P_ _ _ _). If they give you the P300 (multi cylinder misfire), ask them which cylinders exactly... it'll be P301 for cylinder 1, P302 for cylinder 2 and so forth.
Once we know the codes we can help diagnose it correctly.
Good luck
Old 08-27-11, 10:11 AM
snhrph
snhrph's Avatar
The easiest thing to do is to check the gas cap first, before you go through all other steps. Make sure its tight to the click. If broken - buy a new one from your Lexus or Toyota dealer. Should be around $25-$30.
If the gas cap is good, then you will need to get the OBD codes.
Old 08-27-11, 02:23 PM
tz693
tz693's Avatar
To bayer96,
Yes, get the error code read! Even if just as simple as a leaking gas cap, you still need to reset the code after replacing the cap. I can read the code for you if you are in West Orange/Livingston area. PM me if I can help.
TZ
Cookie2016
05-30-16 06:04 PM
jetmelter9
RX - 1st Gen (1999-2003)
02-23-13 12:44 PM
Wronglane
GX - 1st Gen (2003-2009)
13
09-18-11 07:47 AM
nc-longhor
03-21-07 01:10 PM
Quick Reply: Need Help ASAP lights and check engine on???
