Xenon Home Depot HID failure <24 hrs!?!
I've been running the HID's since October.
I'll admit, after an overreaction to being caught by Johnny law and a sour bulb in the beginning...... I have been very happy with my HID headlights and would not go back.
Having said that, my right front fog light HID bulb failed in 2 1/2 months. I’m not sure if it is covered or not but the failure rate was just as high for halogens in the same housing!
Why can't any bulb seem to survive in the right front fog light housing?
Lou
Lou
Lou
Lou
i guess some people do drive no faster than the posted speed limit?
i'm enjoying my setup thus far, though admittedly, i haven't swapped the no-brand name bulbs for the philips i bought from XD as a replacement. too lazy.
Do you think the Phillips are made tougher?
The right front catches more water exposure; a more durable bulb may survive longer....
I'm not concerned about durability. There should no water intrusion into the sealed bulb area.
I want the most lumens with white light. I can't stand anything about the oem 4300K. The philips r the brightest.
Lou
Lou
Contact Steve.
replaced the non-Philips bulbs with the Philips onces from xenondepot. gotta say the philips bulbs are noticeably brighter than the non-philips bulbs.
make sure you guys get the 4300K Philips kit from XD. it's worth the extra cost.
I have noticed some moisture in my drivers side fog, not the passenger. I have the 4300 fogs from Xenon. I took the fog light housing back out and checked for any leaks. None found. As a precautionairy measure, I used a small bead of clear silicone around the two halves of the light housing. The front clear facing is snapped on the rear housing, with possibly some glue at the factory.
It just seems that the 4300 fogs are a hot bulb in a small fog light housing. Much brighter than stock. Would be much, much brighter, if it was for the stock housing.
Update from my post on Jan 22, above. My very small amount of moisture, was on the drivers side of the fog lights, not the passenger. I stated that I sealed the two halves of the fog light housing, with a very small bead of clear silicone (when I removed that housing).
They are snaped together at the factory, and sealed with what appears to be a small amount of plastic glue. I added amount of clear silicone around where these two parts join, and this did the trick from me.
After two hours of driving in pouring rain at interstate speed, no moisture. As stated, it wasn't a lot of moisture in the housing, it was enouigh to bug me when you look at the clear lense. There are (2) vents at the back of the housing, which should be enough to vent.
