Xenon Home Depot HID failure <24 hrs!?!
After hearing raves about Xenondepot HID kits, I bought a kit for my 06.
Now, less then 24 hours later, the driver's side has become dim and pink!
Anyone else have a problem like this?
Nope and I have two of their Xtreme digital kits.
Contact Steve from XD ASAP. He'll help you troubleshoot and get any replacement parts (if any) needed to you post haste. Excellent response times in my experience
Good luck
Good luck
Today, more good news, I read it is illegal to retrofit HID bulbs into Halogen projectors.
The potenial exist to blind oncoming traffic and cause a collision, according to the NTSB.
IMO, although brighter, the pattern is scattered compared to the halogen, a halo appears above the fuzzy cut off point of the HID. It's easy for me to compare since I'm running both halogen and HID since one HID failed and went pink.
Now what??
Now what??
Wow! Are you installing the HIDs on a GX470? If so, no one who has installed HIDs on their GX has heard of blinding other drivers. I've had mind for over a year and no one has ever "flashed" me becuase my HIDs were blinding them. Maybe you installed them incorrectly, eg, not seated properly into the socket.
There is NO issue with their kits on GX's period! I have them on my 08 both low and Fogs and I have NEVER been flashed by anyone as to my lights being to disruptive, I even had my wife drive toward me in her car and she said they looked um "Beautiful" Yea those were her words lol! No blinding or glare! Just pure white light baby!
I guess you installed your HIDs correctly, huh?
Typo last post NHTSA not NTSB, anyway here's the research:
Under federal regulation FMVSS 108, replacement lights must conform to the specifications for the original equipment manufacturer's system they will be installed in. The National Highway Transportation Safety Administration has determined that HID conversion kits can never be designed to meet this standard. The NHTSA declared HID kits illegal in 2004.
http://www.nhtsa.gov/cars/rules/rulings/glare.html
I installed them correctly, if I could replace the projectors to eliminate the halos and sharpen the cut off, I would consider using HIDs headlamps anyway. The fact they are illegal is troubling as there are no indications the kits are for off-road use only or illegal when ordering them from KB.
KB is located is Canada, and like a draft dodger, has no worries about US law or if the kits are legal or not.
That responsibility falls on the US buyer, so caveat emptor .
Obviously a sore subject for those who are 100% satisfied with their HID installs, but don't kill the messenger, this is old news (2004) I just became aware of.
I like Steve and he's been very helpful, I'll keep both kits I bought and will continue to use the HID fogs unless it is a rainy night and reflections may cause other drivers discomfort.
Lou
Lou
Lou
Lou
Most kit bulbs nowadays at least have the bulb properly spec'd to aim properly in the housing.
The 'halo' you see with the GX is mostly due to the 'squirrel' cage which is a cut out in the projector cutoff which allowed some of the original 'dimmer' halogen light to project upward and hit the road signs. Since the HID's are brighter, more light is getting out of the squirrel cage. you can take a piece of metal and hi temp epoxy to cover the squirrel cages and reduce upward projecting light. Of course some additional stray light is due to the reflector in the projector not being designed specifically for an HID bulb (the shape and size of the actual light source is a little different). That is probably why you also do not see the light spread on the road as efficiently and evenly as a true HID reflector/projector.
I have had HID retrofits in both reflector and projector housings (as well as true HID projectors) and I must say the difference in stray light from a properly fitted projector is pretty minimal considering how much more light you get on the road. For a reflector housing (specifically an H4 housing) using a casper shield effectively cuts out the offending stray blinding light. Not using a casper shield in that housing would cause ungodly amounts of glare.
BTW, In the 10 years I have had my properly fitted (or casper shielded) HID kits, I have NEVER had anyone flash me or comment my lights are blinding them, even when I am driving behind cops.
