GX jack tools part# needed
I am looking for a part number from the jack tools that are located inside the rear barn door. Apparently I am missing the extender bar. I have the bar with the square end that goes into the hole for the spare tire but need the part number for the extender bar that attatches to it and extends it past the rear bumper in order to spin the bar to raise/lower the spare tire. I know on my tool compartment all the tools have part numbers on them in stickers. I need to buy the extender and cant for the life of me find one online. If it helps it is positioned in the bottom of the tool compartment. Thanks
Hmmm... not of much help but I just checked mine and couldn't find any p/n for it (no sticker, not stamped and nothing in plastic molded case). Hopefully, someone else can get you the p/n otherwise I suspect you'll either need to call Sewell parts and see if they know or:
- pick one up from a local junk yard or ebay (quick look shows go price is $100 + s/h)
- fabricate one yourself from some steel tubing (should not be hard at all - just crimp the ends to fit)
- buy the whole tool kit from Lexus
Good luck and at the least, this will serve as a bump to keep your post up top
Excellent find BlairC. I used the Sewell parts finder too - looked under body (and powertrain) and could only find the mount and door panel. Makes perfect sense it was under the Engine & Fuel heading, huh?
Oh well, good to see the part is only $10.31 as opposed to buying a whole new kit!
Thanks blairc and burgboxstr for your help. At least I found out it was missing at Town Fair Tire while getting a tire. Now I will call around and see if its in stock.
nutshellml
GX - 1st Gen (2003-2009)
10-20-09 12:01 AM
ToothFairy
07-22-08 06:10 AM
