2003 GX470 wont shift into reverse
When I started the vehicle this morning and shifted into reverse, nothing happened. I turned the car off and restarted it. It made a noise and I shifted back into park. The A/T P light came on. Any suggestions?
Thanks,
Marc
Thanks,
Marc
There are three locations you have a problem.
1. Shift Solenoid Valve (3 Valves) all located within the trans
2. Below the Gear lever you have the Shift Lock Control Module...which needs to be checked
3. The Reverse Gear Clutch ( #3) is defective.
Go to any Autozone, get the OBD tool to scan the results and let us know what are the fault codes found.
Found out what it was
Appearently my kids got into the car and somehow kicked the transfer case into neutral. I put it back and now everything is fine... Go figure. Thanks for all the help on here!!
