Has anyone ever pulled the rear air suspension fuse to keep it in low?
I figure this isn't a smart idea, but thought maybe it could be done with no problems. We don't have rough roads around here. My other two cars are lowered to the point of almost sitting on the ground and I never have any issues.
Can it really be done? If so, report back the results!
A truck is meant to be lifted if anything. Yes, it isn't a smart idea. No offense, bud.
If your other cars are lowered, though, this may feel just like home
becoz if it is via the sensor the apt amount of fluid and air is balanced with the shock using the compressor. But manually done the pump does not read the values recvd frm the sensor. So u end up having a vacuum built with no gas or fluid balancing the shocks. Result bumpy ride.
I think the issue would be that if your bags needed air, and the fuse was pulled (rear suspension disabled), you'd eventually be riding on just the rear shocks...then it would be a matter of time before an accident or blown shocks.
It would be better to "trick" the rear sensors to make it think that the truck is too high (opposite of what others are doing to lift their trucks)
Tricking the GX into thinking it was too high would mean the bags would let air out, to lower it to "normal" height (which would result in a drop)
Tricking the GX into thinking it was too low would mean that there was added weight in the rear, so the truck would add air to raise it up to "normal" height (which would result in a lift)
That's what I did on mine. There are treaded joints that are attached to the rear sensors. Those links adjust, so just give it one complete turn making it longer and you will get lift. IIRC, one full turn making the link longer resulted about 1.5" lift?
