Rear Heat
Rear Heat
Hey All,
I just noticed that my rear heat doesnt work. The A/C DOES work, however. Any ideas? Mann? Know where to start troubleshooting?
Thanks,
Cliff
Thanks,
Cliff
To start with your Troubleshooting, open the Driver Side Engine Bay Fuse Box and Remove the IG1 fuse from the driver side Junction Box & check if the connectivity of the fuse exists if not replace with same ampere, Next if the Fuse is Ok,t inspect the Heater Relay No 1 and check for continuity, This is how you should test the Relay on the following terminals which are numbered (1-2 ) . Check the condition with a Digital tester connecter using the following relay points & should give an output of 62.5-90.9 Ω . You should apply battery voltage between terminal 1 & 2. Connect on terminals 3 & 5 there should no continuity . And Connect on Terminals 3 & 4 it should have continuity.
If there is any different iin the output of the above condition, Replace the Relay.
To check the Relay position in the Junction Box, Once the Box Cover is removed. the inner side gives you pictorial representation of the Fuse and relays.
Notes - Edited
Notes - Edited
Checked fuse - it is still good.
To clarify, the front heat works. The rear A/C blows ice cold when I switch the rear selector to the red side just like it blows on the blue side.
Roger that on the relay. I'll have to check that later.
On a side note - are the Japanese able to see in the dark? I only ask because they decided not to put a light in the engine bay. As an American without night vision, I wish they had put an overhead light in there.
As stated prior. The selector in the second row controls secondary A/C only. You can't get heat from these vents. Heat is controlled from the front selector only and it comes from the vents under the front seats. The selector in the rear is misleading, with the blue and red areas (it only indicates not-so-cold in the red, and freezing in the blue).
Oddly enough I traded in a 03 Explorer for the GX and that had both heat and AC that came out of the ceiling. I could warm that truck up in minutes. I just assumed it was the same when I was at the dealer. I think one of only a few misses on the GX......
