Metallic rattling noise when going over a rapid series of bumps
Old 01-19-12, 05:54 PM
ROK
ROK's Avatar
Default Metallic rattling noise when going over a rapid series of bumps
My truck is making a metal on metal rattling noise when going over undulations or the type of vibration when you drive over a rumble strip.
It seems to be coming from underneath the engine area, but not quite sure. The sound is like a kettle lid clanking on the actual kettle when the water's boiling if you can hear what I mean. No noise when just driving. Maybe I loosened something from driving over deep snow?
Any of you figure this out? I just want some examples to hopefully speed up pinpointing the source.
Thanks!
Old 01-19-12, 06:03 PM
ALAN553
ALAN553's Avatar
Thanks!
It's the anti rattle pins on the brake caliper/pads. Very noisy. Put your foot lightly on the brake, window down while going over some bumps, see if noise goes away. If it does, I am right.
Old 01-19-12, 07:03 PM
ROK
ROK's Avatar
How do I get rid of the noise or is this normal op? Thx Alan!
Old 01-19-12, 08:03 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
There is also a good possibility a sway bar linkage or bushing has worn out...
Old 01-19-12, 10:53 PM
purplehazek4
purplehazek4's Avatar
Could be one of your skid plates, especially if you say the sound seems to be coming from under the engine
Old 01-20-12, 03:15 AM
ALAN553
ALAN553's Avatar
Not normal, the clips cost pennies, Your favorite mechanic,a Toyota dealer! ?? There is a picture somewhere on the forum with pics of a brake job if you are inclined to DIY.
Old 01-20-12, 03:21 AM
ALAN553
ALAN553's Avatar
https://www.clublexus.com/forums/att...s-on-gx470.pdf
Old 01-20-12, 07:55 AM
ROK
ROK's Avatar
Give Alan a prize. I did the light brake over the same bumps no noise. no brakes going over bumps clankity clank.
Old 01-20-12, 10:15 AM
ALAN553
ALAN553's Avatar
The rattle is unmistakable. Annoying when the window is down. But mechanically not an issue.
Old 01-20-12, 10:51 AM
ROK
ROK's Avatar
What's the part # for the anti-rattle spring?
Old 01-20-12, 11:13 AM
ALAN553
ALAN553's Avatar
http://lexus.sewellparts.com/oem-cat...X470-2004.html
Look at swells parts list, it's the parts that look liked bent open paper clip, they are like a few bucks each. Must come with the brake kit.
Old 01-20-12, 11:44 AM
BurgBoxstr
BurgBoxstr's Avatar
Just in case it's not the brakes (and b/c OP said it was coming from underneath, not necessarily from any particular corner)... check your heat shield... smack dab in center of vehicle. When it goes, it has a very "tin-y" rattle. If for nothing else, this will at least help others when they search for "rattles" in future.
Mine corroded after 106k. At first it was intermittent until all 4 mounting points corroded thru and it dropped down completely.
Original post here
Good luck
Old 01-21-12, 07:40 PM
ROK
ROK's Avatar
really appreciate the other sources of rattles - should be very helpful for everyone who does a search on rattle
Old 01-22-12, 08:40 AM
Ancient
Ancient's Avatar
That is why this is such a great site. Everyone has their own opinions regarding what they like and what mods they want to do, but when a problem occurs, everyone pitches in to supply information. I believe that Lexus requires NEW spring clips and plastic shims, with brake pad replacements. The springs get weak over time. Good luck!
Old 01-22-12, 10:05 AM
ROK
ROK's Avatar
got the springs installed.. haven't had the time to find the bumps tocheck noise... also got the philips 4300K bulbs installed. factory brightness. also swapped out the tranny fluid with the toyota world standard stuff of whatever they call it. this stuff is pricey, yes?
Quick Reply: Metallic rattling noise when going over a rapid series of bumps
