Air Suspension Problems or Questions
Old 01-12-21, 09:56 AM
  #391
TargaPony
TargaPony's Avatar
Default 04 Air Suspension Conversion Kit Recommendation
My 04 has 290,000 miles and the air suspension finally just quit completely after about 2 years of not holding air but still refilling manually. I’m having a hard tine finding anyone in my area to do the conversion so I want to buy a kit and take it to someone. Which kit would you recommend? I’ve never replaced the shocks so assuming I should do that too
Old 01-12-21, 10:38 AM
  #392
offroad200
offroad200's Avatar
https://www.dobinsonsdirect.com/prod...0~yr_2002-2009
The following 2 users liked this post by offroad200:
MDSteamer (01-17-21), TargaPony (01-12-21)
Old 01-13-21, 04:31 AM
  #393
losperher
losperher's Avatar
Thumbs up
I vote for Dobinsons too. If you are in FL check exitoffroad.com. Mike is a well know member on another forum. He is in Jacksonville.
offroad200 (01-13-21)
Old 01-13-21, 07:01 AM
  #394
IanB2
IanB2's Avatar
Finding springs and shocks that are in stock might play as big a part in your decision as anything else right now...everything is sold out after a crazy year for truck builds and decreased production due to covid.
For rear airbag conversion kits, I'd say go with Metaltech of Dobinsons, as the SSO kit has some lift built in that you need to factor in when selecting springs or you'll end up higher than you wanted in the rear.
For springs and shocks I've been VERY happy with the 2F/1R springs and twintube shocks (comfort valved in rear) from Dobinsons, but expect a wait as their stuff is very popular right now, and coming over in containers as it's available.
losperher (01-13-21)
Old 01-13-21, 08:23 AM
  #395
losperher
losperher's Avatar
Totally true, due to covid, easily a couple of months of waiting.
Old 01-13-21, 11:11 AM
  #396
offroad200
offroad200's Avatar
My Dobinsons IMS kit took about 3 months to come in.
Old 01-13-21, 11:37 AM
  #397
IanB2
IanB2's Avatar
How's the ride on the IMS shocks? Those aren't adjustable, are they?
Old 01-13-21, 11:52 AM
  #398
offroad200
offroad200's Avatar
Don't know yet. We're installing it this weekend so I'll report back. These are not adjustable. That would be the MRR setup. The MRRs have remote reservoirs, the IMS have internal reservoirs. My buddy has the MRRs on his 2005 GX, the ride is slightly firmer (but that's not bad) than the sportiest setting of the stock shocks. But less body roll and feels more controlled. But the ride on those are great! I just couldn't justify the additional $1k price tag.
IanB2 (01-13-21)
Old 01-14-21, 06:37 AM
  #399
lukasbasic
lukasbasic's Avatar
you could also go with stock aftermarket replacement, not too expensive and you can maintain same functions, this is what I did:
front: OEM shocks replacement (400usd total)
rear: luftmeister aftermarker (250 total, look on amazon, people like them, they do have toyota imprints on them, might be remanufactured)
airbags: I left mine you can do aftermarker on RA for 70 each or so.
which closes the thing in under 800 or so. all parts in stock
Old 01-17-21, 08:52 PM
  #400
derreckla
derreckla's Avatar
Default results
i have the exact same issue as you on ls460l
were you able to figure it out?
when i try tun solenoid tests i turn it to the On setting after 2 seconds it automatically turns off
saw this tonight
https://www.brakeandfrontend.com/lex...ice-2007-2012/
Old 01-18-21, 06:50 PM
  #401
tz693
tz693's Avatar
Originally Posted by gwebster
Hi, I am still trying to diagnose an issue with the ride quality of my GX and wanted to see if anyone has run the active tests using techstream for the air suspension. Specifically, there is an active test for height control and when I attempt to do the test in techstream nothing happens. However, when I use the switch on the console the height control works. Also, there is an active test for exhaust solenoid, and most of the time I can turn it on and off, but periodically I can not. I am wondering if this could indicate an issue with the suspension ECU. However, I do not get any codes. Anyone use techstream and know if this is normal?
The first thing I did after I downloaded the TechStream was to test my air suspension. I got a C1744 (Low Pressure Tank Solenoid) code from the TS. However, my airbag seems to be working correctly, up, nor, down, etc. I can run all other active tests except toggling the the Low Pressure Tank (air tank for airbag compressor) Solenoid on/off.
When I run the Damper Test for the front struts, I can feel the stiffness change by pushing the front end. However when running the Damper Test for the recent replaced cheap eBay rear struts, it doesn't feel any difference. It looks like the cheap eBay rear struts are just with a fake electronic that eliminates the warning light.
Old 03-13-21, 04:00 PM
  #402
Aliwahaj1
Aliwahaj1's Avatar
Default Gx470 2004 , air suspension problem
I have 2004 gx470 150,000 mileage,I bought it 145,000 mileage , i changed rear shocks absorber, then i had still bumpy ride and after 2 months in cold weather my car bottom out , right side all the way bottom on the wheel but left kinda bottom too , I changed airbags both of em , in feb 2021 , 1 month was fine no issue perfect ride , but starting last week air compressor start running randomly during driving , then car lower lit but not bottom today march 13 i jack my car up then lower now i have same situation one side all the way bottom , and because of bottom side air compressor not working i reset the system tryna run air compressor it runs but car not going up not even a 0.1 inch
Please help
Old 03-13-21, 06:53 PM
  #403
chiph9
chiph9's Avatar
You have a leak in the air suspension somewhere.
You may still be under a parts warranty from the mechanic/dealer. Talk to them first.
If you did the work yourself, use some soapy water to locate the leak.
Chip H.
Old 03-14-21, 07:33 AM
  #404
Eliris
Eliris's Avatar
Its possible you took too long to replace you bags and had your compressor running overtime and burned it. Even with leaky bags the car should lift unless ur compressor is out (i.e piston is bad not compressing)
Old 06-23-21, 02:10 PM
  #405
StannMan
7th Gear
StannMan's Avatar
Default Mangled air lines
I got a ‘06 GX470 last minute from my sister when she moved from Cali to Texas.. for cheap. Her husband had the rear suspension converted to a Strutmaster system… It rides like a Truck! During the process they broke the air line connectors where the airbags used be.
Is this an expensive fix? Chinese adjustable shocks run @ $200 a pair. Airbags are as low as $75 a pair. The height sensors are still there (although they still may need replacing). So I’m down to the misc bits for a final cost.
Sooo, do I need oem Toyota parts or will aftermarket parts work?
Quick Reply: Air Suspension Problems or Questions
