Air Suspension Problems or Questions
#406
Don't make the same mistake I made Air Suspension
Two weeks ago someone decided that they wanted to be in my lane on the highway going 75 but didn't see that I was already in the place they wanted to be. They drove me into a divider and totaled my 04 GX. Sbe was gold and aside from the dated color was absolutely perfect. 140k and great. Shame
I began the search in NJ, NY and PA and finally found a well cared for 05 that was in great condition. Mica Blue and clean inside and out.
Only issue was the air suspension was leaking. I tow a lot so I figured might as well replace the shocks.. compressor works as it was going on and off every 30 seconds.
Found a set on Amazon for $135 with good reviews. Replaced both shocks and yes it was a little frustrating but as soon as turned the key the truck pumped up and the ride was great. Took her to get some gas and as soon as I turned off the engine I heard the dreaded hiss... a leak.. after fueling up I hear the compressor going on. Back home and under the truck and see that the passengers side is leaking. Feel around the bellow and nothing. I guess that its probably the fitting on the shock as it wasn't as tight as original.
Remove...add some duct tape.. push in as far as it could go.
reinstall... still leeaking. So much that I can feel the bellow falling. Pull shock and put back original.. still leaking.
Feel around hoses.. no air leaking
Spray soap nothing.
i pull the air line and test it with my compressor. Holding air fine. Reinstall and leaking again. I'm losing my mind.
I set to High. Let it fill up, turn off engine and now I start moving the same fill hose. One section near frame is covered with a small rubber hose. I can hear the air coming out.. I move that hose at the bend and it stops leaking!!
I pulled the hose again and this time I peeled back the rubber section and find a hairline crack that only opens when the hose is fully flexed like it is when it sits in the frame clamps.
I mended it and its now working perfectly.
Ordered a new air hose. Now I'm wondering if the air bags were bad or it was just this hose. The old bags have cracks so needed to be replaced anyway.
check your air hoses!
Spray soap nothing.
TDYalden (08-18-21)
#407
The shocks don't use air.
Any airbag or shock "set" for $135 is not going in my GX.
The plastic tubing can get dry rot over time and crack.
Use Arnott air bags.
Take apart the air solenoid box carefully, clean out the dirt, oil it (sparingly), re-assemble and install.
Tech (08-18-21)
#408
Air Suspension Issues
Hi all - Seems to be a pretty popular topic on this and other Lexus boards. We own a 2006 GX470 and overall, it has been a great car. Recently I started noticing the rear end of the car was sitting lower than normal when parked. I drove it yesterday and the ride was awful, extremely rough/bumpy. Looked under the car and found that the bags are not inflated and the rubber stoppers (not sure of name) are sitting on the axle. Doesn't sound like the compressor is turning on, and I am assuming there is also a leak in the bags or airlines, as previously the car would be lower than normal when parked, but look fine when turned on...
We drive the car 'around town' mostly short distances, to/from work, grocery store, etc. No off roading, no towing, or anything else. Has around 165k miles.
Have begun to do some research, and it seems like swapping out the airbags for coils may be the preferred solution. I had the front struts and springs replaced about 2 years ago with lexus parts. It wasn't cheap, but was the only option at the time. In hindsight, seems like I could have gone with Bilstein shocks and lost the dampening control.
At any rate, what all is needed to keep the stock height but swap to coils? Anyone have experinece with this kit? Strutmasters
The other option(s) I found, seems like I could go with the Stage 1 kit from MetalTech (I dont fully understand the difference between the stage 1 and stage 2 kit, do I need the stage 2?), FJ cruiser springs, and a set of Bilstein 5100s.
3rd option would be to use the same Bilsteins above, with the Stage 3 kit from Metaltech.
Anyone have experience with these setups? Or have any other suggestions to offer? Not sure replacing the compressor, bags, and lines would be worth it at this time, thoughts?
Thanks!
Thanks!
#411
Not sure if it actually needs shocks, but figured for the cost, may as well have them swapped while we're in there.
Thanks!
#412
Following up on this, anyone have any experince with the metaltech stage 3 kit? On paper, seems like a good bit of kit. Just want to ensure I am not overloooking something.
Thanks!
Thanks!
#413
Thanks for the heads up!
Given the age of our vehicles, it's a safe bet that this is going to become a more and more frequent occurrence as time, heat, and mileage take their toll. As with you, I'm having some less than stellar results/performance from the rear suspension on my '05 GX (which is right at 199,9xx miles). I suspect I'll be replacing the airbags and shocks very soon. The only problem is, I just replaced the shocks with (supposedly) new, Toyota-branded shocks about a year ago ($350 pair) and the ride quality improved marginally. I also had Lexus put new airbags on about 3-years ago ($1,200) - ditto on the ride quality. Not having had a Lexus SUV before, I just figured riding like a log wagon was the lackluster experience one could expect. But now I'm thinking there's just no way it was designed to ride so rough.
Lexus wants $1,900 for the shocks and $1,200 for the airbags - insanely bloated prices, especially considering air-bladder suspension technology has been around since about the 1950's. Granted, $135 does seem quite a bit "inexpensive" for those bags/bladders; conversely, $1,200 is also insanely overpriced. This begs the question: where's that sweet spot pricing one would expect, to get a quality product that'll actually do the job? Does anyone have any insight on that note?
As an aside, are you going to upgrade your stereo system from the stock? The Mark Levinson sound system is mediocre at best. It took some time and digging (and $$$, of course), but I was able to upgrade the system to something that sounds phenomenally better without losing AC and navigation/maps.
Thanks, again!
Thanks, again!
BT3100 (08-22-21)
#414
Thanks, again!
Thanks, again!
#415
I opted for the Alpine CDE-HD149BT. I liked the white dot-matrix display over the other Alpine units' displays - they just looked too dated, antiquated, and clunky to me. I added a Fosgate 12" DVC 2Ω sub (run in series), mounted in a sealed enclosure, and paired it with an inexpensive R500X1D Fosgate amp. I also did a full-sweep and replaced all the other drivers, too. It took just a little creative installing - fabricating a replacement ABS mounting bracket for the tweeters in the doors - and the rest I was able to either utilize the existing brackets and or purchase some adapters to allow for non-stock drivers in the doors, so it was pretty rudimentary. The most expensive component was the module that retained all the navigation and AC controls (linked below). Installing it was a relatively simple task. All I had to do was tie into the steering wheel controls with a Metra steering wheel control module.
Below is a list of all the components (I can recall) that you'd need, most of which I obtained off of Amazon. I think I purchased the headunit off of eBay. Just be aware, the mounting depth for the headunit is very shallow. I was barely able to get it mounted and reassemble the dash, and I mean to the tune of about 1/16th of an inch or so. But it fits!
Components:
I had to zip tie the Beatsonic adapter to the steel rail in the dash on the passenger side as there simply wasn't enough space in the dash in the center console. I wrapped the wires using automotive (Tesa) tape. If you take this approach, just be mindful of the passenger-side airbag and any other electronics in this area (see bottom pictures)
Components:
- Fosgate R500X1D Amp: https://www.amazon.com/gp/product/B00BF6HYDE
- Fosgate 12" DVC 2Ω Sub: https://www.amazon.com/gp/product/B004UFHXOM
- JBL GTO20M 2" midrange: https://www.amazon.com/gp/product/B0779KQ397
(Front door midranges, center channel, and rear "barn door" speakers) - Fosgate 6x9 (front doors): https://www.amazon.com/gp/product/B00BF6HWFY
- 6x9 Speaker Adapters: https://www.amazon.com/gp/product/B00IIC6CPE
- JBL GTO620M 6½" Speakers (backseat doors): https://www.amazon.com/JBL-High-Perf...dp/B0767P97W6/
- 6½" Speaker Adapters: https://www.amazon.com/gp/product/B00IIC63P8
- JBL Stadium GTO750T Tweets: https://www.amazon.com/Stadium-High-...dp/B0767PXNXB/
(You'll need a little ABS plastic and a heat gun to fabricate a mounting bracket for these) - 2x Metra Speaker Wiring Adapters for Toyota/Lexus: https://www.amazon.com/gp/product/B01GEIP7RW/
- Metra Steering Wheel Control Module: https://www.amazon.com/gp/product/B00B4PJC9K
- 90° Right-angle RCA's: https://www.amazon.com/gp/product/B076SXWHZ2 (you'll need these or the headunit won't fit)
- 12' Patch Cables: https://www.amazon.com/gp/product/B07Y5T6GXC
- Line-level Input Adapter: (I forget which one I used but Amazon has several to choose from)
- Beatsonic Radio Replacement Adapter Kit: https://www.beatsonicusa.com/stereo/...70/mva-81.html
(Without this, you'll lose AC controls and navigation) - Tesa Tape: https://www.amazon.com/gp/product/B00XPBB6L8
IanB2 (08-19-21)
#417
I am having that kit installed next week.I know its probably not the best kit to install,but,I am not sure how long we are going to keep our 2004 GX which has 205k on it right now.Mileage is not the issue.Its the Blizzard White paint,the stock rims,and the cracked dash all showing its age.Our compressor and air bags are done.This kit has to be better than what we are dealing with now.Iwill let you know once its done.
#418
My entire springs and shocks have been swapped to ome. The ride is so much better than the air bags rode. I also tow and have no issues, Ditch the bags and all the parts that are prone to fail and dont look back.
Good luck
Good luck
#420
Super Moderator
This kit was $450 last year but see price has increased
https://www.1aauto.com/2003-09-toyot...t/i/1aasp00057
